OK last year at legend of the lakes hillclimb it only happined about twice out of 8 runs but when i got to the top of the hill doing 200km/h+ i hit the brakes and they where rock hard as if there was no vacuum left for the booster and just managed to pull her up in time for the 90deg turn.
I know if i back of abit up the hill ill have some vacuum for the top but this isnt an option as i want to win, has anyone got any ideas or come across this? a few of the rally boys told me to just run a bar through the booster they said it would be hard but you have total controll ova the brakes and thats what they do, but i dont want this because its a steet car to.
https://www.sau.com.au/forums/topic/225451-brakes-failure/
Wish I could help mate, but I don't know the answer - sorry. I just wanted to quote this because it's awesome:
That's the spirit you mad man. :D
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3972514
lol yeh but this year i want to win i placed 3rd last year and done alot of mods to the car this year and sponsers have spent big money, and really dont wanna be doing 200 looking at a concrete barrier with the handbrake fully pulled out of the floor i yanked the thing that hard i recon i streched the cable and just pointed the car where i wanted it to go and shut my eyes lol
has anyone hurd of a vacuum auxilary tank or an electric vacuum pump? and where to get one
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3972939
may be there isnt a problem with booster,if the pedal goes hard then it sounds like pad choice?
if it only happens under extreme condtitions then the pad could either be not up to temp, say after a longish straight (200 km) on the climb and you havnt braked for a bit..
just throwing ideas out there.
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3974659
thats another thing i was doing left foot brakein up the hill, what i will to is take it out and give a clean out and see how i go but i found this but they are sold out and will take 5-8 weeks for new stock to come in anyone know where i can get one
Vacuum Brake Auxiliary w/vacuum Gauge Part No Application
TEN-7730 Vacuum Brake Auxiliary w/vacuum Gauge
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3975583
A vacuum pump is required, a storage tank is also a good idea.
Diesel vehicles are the best place to fid one as they have no vacuum to operate brakes by default.
These guys make pumps and have info you might find useful:www.wabco-auto.com/products_and_systems/products-systems-vacuum-pump
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3975681
Just do what the V8 supercars drivers do. Give the brake a little pump with your left foot just before your about to brake to ensure you have pedal feel.
I don't think that (pad knock-off) is the issue here. I've seen this happen a few times on both our toys & old-school blown V8's, once with an impact at the end (ouch) & the cause is instead of the brake booster seeing -ve pressure (a vacuum), it's is being fed +ve pressure from the turbo/'s or supercharger via the plenum. Now I know that shouldn't happen, but sometimes it just does, for whatever reason.
The fixes:
Run less boost/ lift earlier but as Travis has already said himself, "this isnt an option as i want to win" :D
Disconnect & plug the vac-line. Will def stop the prob but at the cost of vac-assist & possibly feel etc.
Pedal box. As above, but at a higher cost.
Go with the vac-tank/pump assembly. Problem solved :)
By rights the check-valve on the vac-circuit should stop this from happening, but if it's failed once do you really want to risk it happening again or have it in the back of your mind, f**king with your sub-concious & maybe slowing you down "just in case" without you even realising it. Piss it off, & go collect a trophy!!
Good Luck
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3976957
raced on standard pads so should have been rite they wk fine cold
Often its the simplest things. You are doing 200km/h on std pads then stamping the brakes and wondering why the hard pedal doesnt equate to retardation? Tells me the fluid is fine as you have line pressure and pedal pressure, the thing jsut isnt stopping which tells me the pads could be glazing, are the rotors std, slotted?
Pads can change pedal feel a lot. Some will make you think you have wooden planks as pads, so hard pedal but just so much pedal effort to try and stop the thing, others are bitey...all feel and react different. If youa re runnig std pads, along with what others have suggested i would not stress too much, its always the simple things.
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3977195
pads, you are using a standard compound in race conditions,our shop sets up lots of traga and dutton cars and never use a standard pad, roy is on the same path, start simple. think about what the standard pad was designed for and the maximum temps it can with stand, not much, it will fade very quickly trying to haul up 1500kg traveling at 200km.
there are plenty of great pads mintex, pagid, ebc the list goes on.
rotor condition as roy pointed out also is just as important, keep it simple.
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3987769
Yes, you might have cooked the pad, especially left foot braking. If you were resting your foot on the brake pedal even the slightest, you could have been adding frictional heat.
I've "been there, done that". Calder, 240Z, stock brakes. Million miles an hour down front straight, into 150 m, STAND on picks, sideways into turn 1. Next time round, same thing - Oh Shoot! hard pedal, absolutely no retardation. Good thing the gate was open on the escape road!
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-3989000
I am willing to bet the left foot braking is the problem. well not a problem but it impacts the braking vacuum assist.
Anytime you have full throttle there is no vacuum. when you left foot brake within a couple of seconds there will be no vacuum left in the cannister, even with a properly working system. I get the same problem in mine across the top of wakefield where I keep pretty much full throttle and a couple of dabs of LFB to bring the nose back around.
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-4000882
dont know if this helps, but when i drive on the street and tap the brakes with my left foot (while accelerating), the brakes are real stiff, then i let go of accel and brake and its normal again..
reason why i do this is coz my friend always tail gates me, wanting to race, so i flash my lights to annoy him :P
https://www.sau.com.au/forums/topic/225451-brakes-failure/#findComment-4003746
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
