Nismoid,
They have it ovaled to allow for better unber body clearance ,Guessing with speed humps etc, HPI do a similer thing where theyrun to smaller diamer pipes into one,
They look very cool but :) I so want one.
There must be a reason why the stuck to a bellmouth style too,maybe more of an applicable range of turbos.,with out the need to remove dividers etc.
There $693 - Delivered from Nengun, Not cheap that is for sure. But amazing quality.
https://www.sau.com.au/forums/topic/225477-new-dump-pipe/#findComment-3972051
Bellmouth fair enough, most are like that...
$700 delivered :)
Holy shit... Tomei dumps for a SET are less than that deliver (RB26), and trust full lenght not far off!
I dunno about ride height though, you'd have to have a pretty low 33 id imagine as there is a fair bit of clearance with their underbody as i know i had problems (HR31) but that was dumps made for the R33 :cool:
Im sure its a great dump either way
https://www.sau.com.au/forums/topic/225477-new-dump-pipe/#findComment-3972094
$700 delivered :)
Hi there, can you put me onto the supplier for Tomei dumps at <$700aud (RB26) delivered please? My last quote was $900aud.
Cheers GW
https://www.sau.com.au/forums/topic/225477-new-dump-pipe/#findComment-3972281
$700 delivered :D
I dunno about ride height though, you'd have to have a pretty low 33 id imagine as there is a fair bit of clearance with their underbody as i know i had problems (HR31) but that was dumps made for the R33 ;)
Well i know nothing beats handing over your cash for a CES Split dump, have it Hi temp Coated, then flatten the bottom out on a god damn speed bump. So this looks like a good idea to me!
https://www.sau.com.au/forums/topic/225477-new-dump-pipe/#findComment-3972312
  • 10 months later...
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
