R33 gtst
ecu - unichip with boost control module. this module controls boost via the standard solenoid, through the ecu. i dont know any more specifics than that
recently my boost dropped from 12+psi which was set on the dyno during a tune, to what seems to be stock boost.
basically i drove home from the tune, saw 12+psi once on that trip, and parked the car. 2 days later, stock boost level.
its now running about 9psi, which i'd consider stock for 3 inch exhaust, fmic, and pod.
just for the record, ive had this ecu and boost controller previously tuned (same tuner) and working flawlessly for ages before this.
i instantly thought one of the hoses to and from the solenoid and actuator might be stuffed. checked all those, they are fine. no blockages or leaks.
(even though a leak or blockage in most cases would cause higher boost)
then i thought it might be the solenoid itself. i could only find a VL solenoid, so i tried that, but no change, then i tried it back to front :D , coz they are slightly different than the r33 type, and i wasnt sure of orientation. it then boosted to 15psi. so i figured they are spec'd differently, and a factory R33 solenoid would fix my issue for sure. well i got a used one, and no change. still running stock boost.
ive checked voltage at the solenoid plug, it shows 12.?v at idle.
the car drives fine, pulls hard, but only to 9psi, so its not likely theres leaks in the cooler piping etc. ive looked anyway. even blocked the bov just to make sure it wasnt leaking from there. plus the 15psi kind of discounts these.
the car will be going back on the dyno shortly to see if its the actual boost controller/settings. the guys have been moving to a new workshop, hence the delay.
so, besides boost controller, has anyone got any thoughts on what might cause this?
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/225490-boost-has-dropped-back-to-stock/
  • 3 weeks later...
after sorting through the flood of replies :laugh: i thought i'd better post the result.
turned out to be the boost controller. still have no idea why its playing up. works on the dyno. fails as soon as it back on the road.
tuner is guessing its a wiring issue. but i cbf booking it in for troubleshooting, investigations, and surgery.
so anyway, fitted my turbotech mbc back up. ooooh how i missed the boost. :cool:
Edited by Munkyb0y
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
