atm have a l24e+t that likes to ping is ass off over 6psi. compression accross all 6 is between 168-172psi. head was rebuilt few months ago and i think too much was machined off.
im wanting to lower the compression so thinking either thicker head gakset or a shim.
what would b the better option? whats the std thickness of a l24 head gasket? how much thicker (if possible) should i go? also any thoughts on these shims? seen them b4 just thought was dodge that they r glued to the block (1 i saw done one a gemmie anyway). guess two flat serfaces so should seal alight under boost?
but yea any info would help me out heaps
cheers...
https://www.sau.com.au/forums/topic/225496-l24-compression-problems/
if you have the E88 head, it is lower compression than my N47... so Im officially worried!
I think if you get a gasket taken to a metal laser cutting/waterjet place and get them to make up a 3mm copper gasket to start with
(i think the HKS ones were 3mm)
i think if you get a N42 from a L28 it might lower the comp a bit....
Ghostridcer will know.
I was warned, by a knowledgeable person, when I proposed this some time ago that the engine would likely ping because the head wasn't designed to handle a turbo.
What ECU are you running? How much was shaved off the head? And did you pack the cam towers to compensate? (maybe the cam timing is "off" (retarded))
Why not get a head from a wrecker, get it machined (port, profile combustion chamber) to suit a turbo app. Might be a bit more expensive, but I'm sure it would be a better outcome in the long run.
I think a L28 head is unsuitable because the L28 is a bigger bore than the L24 (?)
cheers 4 the feedback, yea have read about the combustion chamber being unco for boost (half moon) but mate is running l24et n47 head, 10psi no worries. smaller injectors, smaller turbo and fmic and stock ecu. (u should b ok andrew lol)
im only runnin stock ecu.
no idea how much was taken off the head and theres no packing under the cam towers. timing is spot on tho and chain is tight. unless need a vernier cam gear if its a pooftinkths out?
the head its self is good (just been rebuilt) so was hoping to use thats still with maybe a spacer, thicker gasket etc. or after market ecu would be the better option?. but then if comp is too high still wont b able to run much more boost?
1st ill borrow some IPA from work and test out this water injection set up as metho didnt work lol. was alot better but still ping country after 5k...
Edited by OUTATIME
with alcohol in there it deff did make a power difference but still pings after 5k.
thinking about a adjustable fuel reg. to richen it up when on boost. cos plugs r white after a thrash, black after puttin around.
http://cgi.ebay.com.au/New-SARD-Adjustable...1742.m153.l1262
any1 had any experience with those regulators? worth getting 1? i had a cheap ass monsta one b4 on my 31 but did f*k all and just broke in the end. dunno if it was a rising rate or not.
cheers...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
