Service Question- Tranny Fluid
kidafa
 Share
Hi All,
Well its nearly time to do the 1st service on the stag since I've owned it...
Im planning on doing the following:
  • Oil And oil Filter
  • Brake Fluid
  • Front and Rear Diff Oil
  • Tranny oil
Ive allready done the coolant when i did the timing belt so thats ok....
The question I have is about draining the tranny fluid.. Ive read many different ways to do it, eg the plug or out the cooler lines....
Which method do you guys use and recomend to get the most out of the system that i can?
Have I missed anythign that I should be doing?
Cheers,
Chris
Hi All,
  • Brake Fluid
  • Tranny oil
Cheers,
Chris
There should be a drain plug on the bottom of the gearbox. I'd be draining it from there. or faster draining, remove the dipstick at the same time. :P
Ive herd that this will not get all of it out though....
few ways to do it, best is go to tranny shop, special machines that replenish the fluid.
Fill and drain it a few times.
or drain it, refill, disconnect cooler hose, sucking end in fresh fluid, other in drain, run it until out fluid is fresh
If the fluid isn't pressurised as it is fed into the trans, you will never get it all out due to the sheer volume that the torque converter contains (that will not come uout under gravity). Either get it flushed at a trans specialist, or drain and refill it about 4 times in a week. Its about the only way I know of to get it all out, and it would be a LOT more stuffing around,and probably more expensive, than getting a specialist to do it.
/\ 2nd that
On a side note, you mentioned changing the brake fluid? What is your procedure for bleeding the stagea's abs system? the compliance shop mechanic told me they had to be vacuum bled. Is there a way it can be done at home?
Hi All,
  • Brake Fluid
  • Tranny oil
Cheers,
Chris
I have just done the auto fliud - what a mission!
Drain the pan but note that the plug is not at the lowest point so when you drop the pan it will still contain fluid (yep it went everywhere). You need to drop the rear gearbox mount to get the pan off so you need plenty of stands/jacks. I replaced the filter but the one supplied was not quite right - had to cut off some of the square pickup pipe. You could probably just wash the old one. The pan was full of gunk so I am glad that i took it off. I put the pan back on (after I worked out that the new filter was stopping it from going on) and then pulled off the supply hose to the oil cooler and stuck it in a plastic 2L bottle and ran the engine til it filled. then I poured 2L of new fluid down the dipstick tube and repeated until the fluid ran clean. I used about 15L in this process ( I got a 20L Fuchs Titan 4000 semi synthetic cheap $60).
My last Stagea I took to an auto service place that did a flush for $300 and they didn't even take the pan off so by doing it myself I am satisfied that I got it as clean as possible even though it was a major hassle. Even if you have to pay more for the ATF it is good for your peace of mind to do it yourself. You will probably only ever have to do it once!
thanks for the writeup KiwiRS4T :P My RS4 is with MV Automatics in Adelaide today getting just that done (and a valve body upgrade :huh:) which is a fairly reputable place here in Adelaide so I hope they at least drop the pan (well it's getting a service and they said they're fitting a new filter so I assume they'd have to drop the pan)
I asked about flush/fill and they said they only refill the pan (:D !) and only flush the rest of the system 'if the oil looks like it needs replacing'. Hmmmmkay.... for $300 for a service, like you say, it better be a good job (although for a complete refil I would expect at least $100 of that to be gearbox oil cost alone).
KiwiRS4,
IF i drop the pan do i need and gaskets or anything or it simply open her up and bolt it back together once im done?
I bought a kit with a gasket and a filter but when I dropped the pan the gasket was stuck to the pan so it could probably have been reused - you could always put a bit of gasket sealer on to make sure I guess. (Make sure you have a plan b - someone else with a car to go buy a gasket in case you destroy yours getting it off but mine came off in one piece OK). Good luck!
  • 2 years later...
Can anybody quote the tranny filter kit number for a Stagea S2? I think I have found a kit locally but would pay if I can find another S2 owner that can quote numbers.
 Share
    • Gosh these bmw's are worse money pits than JDM's! I won't complain about my car anymore 😂
    • I'll just leave this quick tip here after reading your joys of getting the car in the air. It should take no more then 10 minutes to get the car safely up on stands.  So for the front, jack on the tow recovery points (marked in red). Put the jack stands under the lower control arm mounting point (marked in yellow). This photo is of a R34 GTR, however the process is the same. For the rear, jack under the diff (marked in red). Put the jack stands under the rear subframe or where the lower control arm mounting point (marked in yellow). Which point you use will depend on your stand, pick a nice stable point.  You've probably already read this but it's worth repeating. When jacking up the car or using stands, stay away from the chassis rails/pinch welds. Even the factory jack point, stay away from that too unless using a factory jack. I used those jack points for years without issue until I turned into an old man and bought a QuickJack lol.
    • And this is where the leak is happening: https://www.dropbox.com/scl/fi/7h1vlmg2j5aa7rksvsjc9/IMG_9982.jpeg?rlkey=d3bnpau5f615zmxqmca0llvr7&st=kquvdxvs&dl=0   Apologies but it seems adding an image from a link does not work when the images are in Dropbox.
    • Here are some pics from the auction: https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0   https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0
    • Hi all, From the western suburbs here. Just got my 2000 R34 GTT registered today! Got it imported from Japan through a mate who is doing them and managed to find a decent one. This one has only done 110,000 Km and had no body rust etc. so was very happy. I used to own a 25Gt back in 2015 (ate Ramen noodles for years to save up for it), but unfortunately, it got stolen TEN DAYS after I bought it!! Came back from Uni and the car was missing - cops found it in Springvale a month later with a lot of needles  😒 It was too late by then and I had moved on to a different car (300ZX), and after that one got broken into around 2018, I was in a very bad place and decided I would never buy a car again because it was just pointless!!! ~yeah, I have some very bad mojo~ 🥺 But now, with a stable job and a secure garage, I thought I'd get the R34 4D again but not as a daily! I love the R34s but a GTR is still a bit off my pay grade so settled for the GTT instead.    The first step for me is to get this car serviced and have all fluids, belts and spark plugs changed. I might do the brakes at one point too but atm they are fine, the fluids are what I want changed since this car probably sat in a garage for a long time. I'll then get some coilovers since the suspension needs to be changed anyway (the dust cover kit is disintegrating). I'll also upgrade my car alarm to a Viper system and then look at rims and tyres (I'm a sucker for TE37s - might have enough saved in another 3 years for that).   Today: I was planning to do the oil, coolant, air filter and fuel filter change this week. Started on the oil change today and MY GOD what a pain!! I used to think the 300ZX engine bay was cramped - oh I was so wrong! 😂 I've done the usual services on my cars before so it was not like I was going in blind. I looked up all the forum details about what oils to use, what coolant to use, what points to use to jack the car or place stands etc but I did not expect it to be this hard. Long story short - all I managed to do was the oil and filter change. I think I might end up taking it to a mechanic for a coolant change because my SCA stands and trolley jack just can't get far enough underneath to the cross-member and I don't want to be crushed under my favourite car....yet. Side note: In Dandenong, there used to be a shop that lets you hire their hoists - does anyone know if they have those around? I can't seem to find the Dandenong place anymore. I contacted them off FB almost 6 years ago and I'm not in it now. If anyone know of one, that would save me some time going to a mechanic for the basic services. Oil: Dark and gooey but no metal pieces. Oil Filter: Was a b***h to take off but no red flags Air filter: Yucky! Was black (Smells like fuel which makes me think it may have been running rich? - am I way off?)   Concerns: I have but one concern atm and that is that there was a very small amount of oil leaking where the engine and the transmission connect (Automatic). It may be the rear seal? It's not a massive leak and it does not affect the oil pressures or leak oil all along the driveway. It's been falling into the cover this whole time. I've taken the cover off so I can check the garage floor from time to time.  I also have not seen my engine temperature gauge ever sit at cold and slowly move up to the right spot, but that might be because every time I saw the car today, it was running. I'll check that again tomorrow. ATM it just sits right in the middle. I may just be paranoid but I don't want an overheating engine while my gauges say everything is fine. 🙈 Other than that, I'm very happy with the car! Feels like it's about time I went back to spending my weekends driving or cutting my arm on stupid sh*t in the engine bay.   PS: I will post a pic later on because I underestimated soooo badly today and it was dark by the time I finished! PPS: I broke the two damn plastic pins that hold the intake funnel section to the front bar. This is the piece made to bring cold air to the airbox. The connection to the airbox is fone, but the two clips just broke off! Should I be worried? Anyone else done that?
