Hey got lots of parts left over from a rebuild!
Nismo AFM x2 BRAND NEW $350 for both
R32 gtr front strut brace $60
BRAND NEW 11 row oil cooler no lines!! justjap one $40
BRAND NEW 11 row full oil cooler kit! just jap $240
Standard gtr rods and pistons $150
Standard 6 coil packs $50
2 top intercooler pipes for gtr. Justjap $60
All in hobart
Ph 0417130160
Cheers Adam
https://www.sau.com.au/forums/topic/225592-parts-clear-out-hobart/
very interested in complete oil cooler kit, pretty sure i will take it. I can see its b/n, how long since you purchused it and do you still have the reciept incase new owner need to claim warranty? , cheers Damo
Edited by madaz R33
Hi man
I am stuart the bloke who spoke to last night about the AFM'S.
Did you sell to other person?
If not as i said i will pick up and pay saturday or if you need money before that i will deposit into your account tomorrow.
Regards stuart 0437191618
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
