I threw in a "GTR ACCELERATOR PEDAL FOR SKYLINE R33 GTS-T" from unique auto sports onto mine about 3 months ago and haven't looked back. I'm too lazy to get my heel across for a true 'heal toe' and have found this little puppy to be a gem. Did require some gentle persuasion to fit it properly though.
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3973903
Heard that this was really good for driving. gettin one soon
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3974725
Dont laugh this is serious...
If you are having trouble getting "traction" on your standard pedals go to Bunnings and buy yourself some really coarse sand paper (at least 40 grit) cut it to the shape of your pedals and stick it on with some seriously sticky glue.
The change of grip is certainly noticable! - Cheap easy and effective, great mod :laugh:
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3978049
I got one of those pedals from unique autosports sitting in my cupboard cos someone wasn't able to fit it to my car, even with a bit of cut'n'persuasion ... I'm still curious if it actually DOES fit. Someone whose fitted it successfully gimme a PM? Thanks.
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3982759
One of "those pedals", what brand, Razo???? I can have a look at how they fitted mine and send dirty pics maybe!!
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3983167
One of the UAS R33 GTR pedals. Person I gave it to to fit had a go, but even after hacking out some of the back of the pedal, wasn't able to get it to fit :miner:
Are you able to fit that pedal and remove it after if you don't like it? Otherwise I'll look at Momo's or something later on
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3984889
One of the UAS R33 GTR pedals. Person I gave it to to fit had a go, but even after hacking out some of the back of the pedal, wasn't able to get it to fit :whistling:
The problem with the UAS one is all the cross hatching from the moulding on the back side gets in the way because the r33 gts-t pedal has a plate welded over the top. Just get a sharp chisel and gently cut the cross hatch away. Once you fit it yes you can take it off again just prise the safety clip open then pull off. If I can be bothered I'll pull mine off and put some photos up but I warn you, I'm pretty slack.
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3988000
Yeah, the person who had a go at fitting mine started to cut away the cross-hatching, but only near the top next to the safety clip, then they stopped. If you removed ALL the cross-hatching, wouldn't that weaken the pedal significantly? It's only plastic.
https://www.sau.com.au/forums/topic/225632-pedals/#findComment-3988273
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
