Yeah, the person who had a go at fitting mine started to cut away the cross-hatching, but only near the top next to the safety clip, then they stopped. If you removed ALL the cross-hatching, wouldn't that weaken the pedal significantly? It's only plastic.
It doesn't weaken it as there is a full metal backing on the actual pedal, the plastic cover is quite strong.
All you have to do is cut enough of it away so that the cover sits around the actual pedal.
Here's the pedal and the plate you have to clear;
Here is the back of mine, not pretty but you can't see it from the front.
Here it is installed
The pedal is still strong, it doesn't move or slip at all and has made all the difference for me anyway. Just have a stab at it, the worst that can happen is you put the old one back on. :D
https://www.sau.com.au/forums/topic/225632-pedals/page/2/#findComment-3988855
Great! Thanks for the photos. One more question - is there a clip holding the original pedal on? and can I reuse it? Because I see that you have something like a top part of the clip that I didn't get from UAS. I just got one piece of pedal (unless it's gone missing, but I never saw it in the little baggy before it was opened).
https://www.sau.com.au/forums/topic/225632-pedals/page/2/#findComment-3989977
The original has a C clip that clips around the top of the pedal with a saftey that then wraps around behind the metal down rod. The UAS has the exact same clip and as far as I can tell they're not resuable. Both the original and the UAS is a single unit with the clip moulded into it.
https://www.sau.com.au/forums/topic/225632-pedals/page/2/#findComment-3990262
Dont laugh this is serious...
If you are having trouble getting "traction" on your standard pedals go to Bunnings and buy yourself some really coarse sand paper (at least 40 grit) cut it to the shape of your pedals and stick it on with some seriously sticky glue.
The change of grip is certainly noticable! - Cheap easy and effective, great mod :D
Skateboard grip stuff is like that, but self adhesive, hence easier. Just keep rubber ones in your car incase you get pulled over lol. That's what I plan on doing anyway. I stole the idea from autosalon magazine lol.
https://www.sau.com.au/forums/topic/225632-pedals/page/2/#findComment-3990319
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
