Anyone have any experience with this ?
I collected some data from my datalogit and found a dyno run, I found that both knock sensor read outs were different....
Knock sensor 1 and knock sensor 2 were like 20knock out from each other and one spikes to 100 and the other only goes to 60ish
I know on high powered RB's the knock sensors become un-reliable.. We cannot hear any pinging or detonation while running on the dyno.
I want to buy Gizzmo KMON but cannot afford it till next month i dont think....
Can anyone say whats going on here? or should i just forget about these readings alltogether? this run made over 350kw at the wheels.
https://www.sau.com.au/forums/topic/225728-knock-readouts-on-dyno-run/
My cents are, they're prolly old sensors, as they're both the same rough shape, just 2 is more exaggerate (vice versa)
Though to diagnose, assuming sensor 2 is at the back; could you trim / richen up the last 3 cyls to check for an effect on knock?
hey Anthony,
Try swapping the sensors or just the cables around and see what happens... It may be that one of the sensors has lost some sensitivity
..I've got a couple of of stock RB25DET knock sensors sitting on the shelf ...you can borrow them for a while of you want...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
