stock r33 s1 turbo dump and dowm pipe.
price $300
stock rb25 manifold
price $50
stock r33 cat back exhaust
price $100
stock r33 suspension
price $100
stock r33 fuel pump
price $50
stock gtr catconverter
price $50
2 seperate pairs of 17/8s jap rims
price $150 a pair or $250 for the set
r33 hikas lock bar
price $60
also my rims off my car fronts are 18/9s and rears are 18/10s
front tyres are camber worn 235s and rears are brand new 265s
im not sure of the offset i would check the rays sticker inside
the rim but car is currently at a workshop.
price $1400ono
also sa adelaide only thanks.
please do not pm me.
msg or call 0410201806 thanks travis.
Edited by hks2540
https://www.sau.com.au/forums/topic/225740-stock-r33-get-off-defect-parts/
you willing to post at all at buyers expense??
when you get the car back from the shop could you let us know the offset please,very interested.
cheers
Edited by fknryt
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
