stock r33 s1 turbo dump and dowm pipe.
price $300
stock rb25 manifold
price $50
stock r33 cat back exhaust
price $100
stock r33 suspension
price $100
stock r33 fuel pump
price $50
stock gtr catconverter
price $50
2 seperate pairs of 17/8s jap rims
price $150 a pair or $250 for the set
r33 hikas lock bar
price $60
also my rims off my car fronts are 18/9s and rears are 18/10s
front tyres are camber worn 235s and rears are brand new 265s
im not sure of the offset i would check the rays sticker inside
the rim but car is currently at a workshop.
price $1400ono
also sa adelaide only thanks.
please do not pm me.
msg or call 0410201806 thanks travis.
Edited by hks2540
https://www.sau.com.au/forums/topic/225740-stock-r33-get-off-defect-parts/
you willing to post at all at buyers expense??
when you get the car back from the shop could you let us know the offset please,very interested.
cheers
Edited by fknryt
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
