Sorry to say that I have lost my BCM code (even my backups were blank). I hear that Nissan Japan won't help anymore and I can't seem to get in touch with TomR33. I still have two keys but I would like to have the code just in case.
Anyone around that can get the codes for me?
Thanks,
  • 2 months later...
Hi everyone, My 2003 Coupe came with only one key. Following earlier posts I emailed Nissan Japan the info from behind the kick panel. They sent the code to Nissan Oz who forwarded it on to my local dealer (country WA) All good so far! Now the dealer is confused as to what key to encode. If anyone out there has been successful in getting a new key, can you please tell me from which Nissan vehicle it came from? I wondered if a Maxima key would do the job. Cheers.
Do you have an aftermarket alarm? Are the black, plastic tags used to disarm it?
Try swapping them around.
Not sure if aftermarket or not. the dealer installed it during compliance. i was told that the black tags must be near the ignition switch. i assume it disables the oem immobiliser.
  • 5 months later...
Sorry for digging up an old post.
I to was only provided one key and my car didnt even come with a remote, so i grabbed the info from my side kick panel and ive e-mailed Nissan Japan, incase they fall through i thought id post my BCM number info here with the hope someone will help me.
Thanks again guys really appreciate it.
Hey Guys,
I know this topic is old but jst letting you know if nissan australia tells you they cant help you with ciding a new key/remote they are liying out their arse, after arguing with a couple of dealers i found one in artarmon "Mildren Prestiege" they were able to code me a new set of keys with remote as well as the full programming of an intelligent key for $301.00 i previously only had the key without the remote, great having all the features
I find it funny that the local dealer calls me to code keys to these cars . it is even more interesting when they hand me thier C3 and a car and a key and a immobiliser code..
nissan japan won't sell me keys and will point me and everyone else wanting keys back to nissan oz who are supposed to point them to the dealer. dealers are told not to touch imports due to the R35.
fun and games..
Dealers should touch them Chris, they should touch them very intimately! lol
Apparently you can just buy the remotes off ebay that can be coded with instructions to your V35, but you need to buy a key to cut separately
IF that's true, then f**k yeah
Edited by Murry33
not entirely. but hey its on the net it must be true...
still need to program the transponder into the car. someone else has to do that
This is the hard part. Still haven't found someone keen to touch mine for less than $150 (which I reckon is a little excessive because they will do non-imports for less than half that! Don't want to pass over my hard earned to some knob with that mentality).
  • 1 year later...
Hey guys, new 2003 350gt owner here.
I only got one set of keys with the car. I have had a browse around on the internet trying to find replacement keys to no real avail.
I have attached a picture of the set. I have figured out that the little button one is my immobiliser key so Ill have to get in touch with the manufacturer of them to see if I can get another from them. But for the main key, is this one shared with any other cars which were available in Australia?
Am I pretty much stuck with dealing with Nissan Australia to buy the actual spare and then can I get it cut at other places (I have seen Bells Locksmith/Abbotts Locksmith/JapLink mentioned) or do I just pull out the KY and warm up my credit card swiping arm?
you can get the physical keycase and blade on ebay - http://www.ebay.com.au/itm/NISSAN-3-BUTTON-REMOTE-KEY-SHELL-KEY-CASE-MICRA-350Z-PATHFINDER-NAVARA-/221126171658?_trksid=p2054897.l5659
However, you are going to need the immobilizer chip and remote central locking module and then have your car programmed to accept it. I am not sure if any ADM model nissans use the same type of keychip and/or central locking remote.
If you can find out if another ADM nissan does, you could try to find a 2nd hand key, take the keychip and remote board out, fit it to the case from ebay above, have the key cut at any locksmith, Then take the car to Nissan to have them program the BCM to accept both keys and both remotes.
Edited by sonicii
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
