Hi,
The key for the JDM 350GT Coupe are a transponder type and are coded to the cars main ECU.
There is an amplifier near the ignition switch which picks up a coded radio signal from the key. If the code matches the code in the ECU the engine will start.
You can demonstrate this by having a flat key cut and inserting it into the ignition switch. When you turn it the engine will turn over but not start as the ECU won't switch on the engine management system. If you then hold your real key by the switch and then turn the engine over it will start.
This is a very secure system but it does mean the keys are very expensive. You need to give the Nissan dealer your chassis number and model code from the plate in the engine bay and they can order the key for you. Nissan Japan holds the information on the key type.
You then get the key cut to match your original key and take all your keys and the car to the dealer and they will reprogram all the keys to work. If you don't take all the keys the key you didn't take will no longer work because reprogramming erases the previous codes.
If you only have one key do not lose it as the only way to get your car to go then will be to by a new ECU and keys.
My new key cost me $650 here in Auckland and the programming cost $50. It's a hell of a lot cheaper than an ECU so it is worth doing.
I would be very careful about buying keys from any other source as it could be expensive in the long run.
This security system is very similar to what Kawasaki uses for their imobilizer equipped motorcycles and it is very hard to defeat but expensive if all keys are lost.
Regards
Wayne
Edited by Wayne NZ
Hi,
Regards
Wayne
great, practical info there mate...thankyou.
But how does the RED valet key work?...is there also a 'radio circuit' (minus the controls) of sorts in them too?
(Soz if this has already been answered)
I don't know with those. I did not get one with this car.
Wayne
same idea as the remote style key. both have transponder chips in them both are programmed to the car.
Thanx Chris.....so it's the same as the black keys....minus the magical buttons!
Thought that was the case...thanx buddy!
Spit.....still waving the CR banner.
I have experience in that side of it. my van runs the same setup. it was sold with two plain keys and I added a remote one to it,
no need to wave flags :D
I just work on these things...
cool, thanks man.
Can you believe that I've still got the original Jap battery in my car....I managed to find the date stamp!...(but could not read the CCA rating of this battery.)
(sorry for digressing, just thought you'd be interested in that!).....I managed to track down a 330CCA with correct power-pole postion and size, ..I reckon that will be ok for my v35...would you agree Chris?
Spit.....now waving the 'wave no-banners' banner.
  • 1 month later...
2001 HV35 didnt have it. 2003 PV35 and CPV35 did have it.
Chris, for those who does not have the NATS, would Nissan still be the only means to get a spare remote (for door lock/unlock & boot, no key)?
Does that mean that the G35 remotes available on ebay motors could be usable in V35 that does not have NATS? .. like this ones
http://motors.shop.ebay.com/_Car-Truck-Par...QQ_fxdZ1?_rdc=1
to be honest I would look more at a GQ patrol key. I put a price up on one of those in the car audio section.
if you have a chassis number I'll look up a replacement key for you and give you the part number
to me its common sense :glare: they are different to everyone else for their market what makes you think they would sell a car that is the same as another market. hell the radios in these things differ widely from USDM -> JDM. (says he thats trying to crack the 2005+ versions..)
correct. I should really write a FAQ for all this stuff..
Hi,
I finally got my act together and got a spare key programmed for my 2004 V35 and it works fine. I purchased the key from Nissan spares using the chassis number ($141) had it cut ($20) and then had it programmed by the Nissan service dept at Gosford NSW ($30). I used the pin that I got from TomR33 and from Nissan Japan which were identical and the programming took 5 minutes. Quite an easy task.
Hi,
when y say 141 is it standard catalogue $ amount for spare key or does that differ from dealer to dealer
which email of nissan japan did u sent to? Mind telling me? i need a spare key desperately.. thzz
Hi,
I don't know if $141 was the standard price but I know locksmiths charge $110 - 130 for transponder keys but their programming instruments do not recognise Nissan keys. The email to nissan japan for the code is: [email protected] but TomR33 can also give it to you. Check the previous posts in this thread. Good luck
did read the tread, but not sure if TomR33 still available for providing the help..
but still pmed him..
thz for the nissan jap email, i missed that somehow :)
mayb will try to get a switch blade key when i got the pin code :(
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
