Ps3 + Samsung 19" Lcd
dezz
 Share
Ok so I'm getting really pissed off now, and before I put a fist sized hole through the LCD, I'll see if anyone here can help out.
Its pretty simple really...I've got a ps3, HDMI cable and a Samsung 19" LCD (LA19R71BX: Link to specs)
The PS3 works fine in full HD downstairs on the 46" Samsung M8 LCD, but people are usually watching that TV so I need to get it working up here as well.
Basically I plug the HDMI cable into the LCD, switch on the PS3 and LCD, and hit the 'source' button to get it into HDMI mode, where all I get is a blue screen and the message 'mode not supported'
Considering the TV is HD, has a HD input, I see no reason why it shouldn't work!
Hopefully someone here knows why and can sort it out for me.
Cheers
Holy shit... it only has a 8ms refresh rate. I didnt even know they made that anymore
i think it may be that you've set the PS3 to read at a cetain output level on your 46 incher, and now that you've moved down to a possibly smaller output level TV, your not getting the signal. You may have to plug it back into the bigger TV and screw with your settings.
a tech head may be able to explain it better, but im pretty sure thats teh problem
Edited by ctjet
I took it back downstairs the last time I tried to connect it up here...the resolution setting is set to auto so in theory it should really adjust itself to the TV its being connected too...seems pretty stupid if you have to set it up on the other TV everytime you want to move it from one to another.
I don't know much about the PS3 since i don't have one, but that TV says it's HD ready. It just doesn't have a full HD res, which shouldn't matter, it should take the 1080i signals and display it anyway. Doesn't the PS3 do 1080p? Maybe the TV doesn't like that, it wants 1080i?
Screen Size 19"
Resolution 1440 x 900
Dynamic Contrast Ratio 600:1
HD Ready Yes
LCD 100Hz N/A
Try this Dezz.
1) Set the TV to HDMI mode
2) Connect the HDMI wire to TV and PS3
3) Hold the power button for 5 seconds until you hear 2 beeps
switch between the different HDMI channels if u have more than 1.. and look for a picture...
you dont have to disconnect anything in the back of the tv... just make sure the HDMI is the only video output attached to your ps3.
2) The secret video reset
One of the most annoying aspects of the PS3 are its video settings. Take it up to the bedroom portable or round to a friend's house and there's a good chance that you won't be able to see anything on screen because your 'new' TV is running at a different resolution or using a different cable connection. And - because you can't see anything - you can't change it.
Until now. Shut down your PS3 then restart by pressing and holding the power button.This will reset your PS3 to its most basic 480p graphics mode so you'll be able to see enough to choose RGB SCART, component, HDMI or whatever from here.
gave it a go, but holding down the PS button did nothing, apart from switch it on initially.
I tried it 2 ways, once with the PS3 off, pressed the PS button (which switced it on and continued to hold it waiting for 2 beeps), got nothing.
Then with the PS3 already on, I held it for more than 5 seconds and still got nothing.
none of that reset stuff worked for me, but just now I've managed to make it work on this TV...in the most ridiculous way possible.
I took it downstairs, switched it on, and then went through the steps to get to the display settings auto setup part...I wrote down how many times I had to press each button (X, 4 left, 9 down X, X, X, X) which gets to the auto display setup. Then I brought it back upstairs and did it all again blind.
If thats what it takes to get it working every time then Sony are a pack of absolute retards.
You can try to set the tv to 60Hz, commonly used with game consoles these days, also the tv is only capable of 720p display output so set ps3 to that on your larger screen 1st, as you are already de-scaling the picture resolution from console as tv is 1366x768 maximum display resolution not 1980x1080p as your larger monitor is capable of. If all that fails get on the line to samsung customer support 1300# and they will talk you through setup :)
 Share
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
    • they choose the number of psi (27) around 4200? Could it produce more at this engine speed with the same turbo?
    • one thing escapes me, if the turbo spool provides the maximum boost and we can't control anything before that, how can the boost be higher by it alone.   here around 27 psi at 4200 then up to 32 psi at 6500 rpm   how does the tuner do this
    • I'm still not sure what you are trying to acheive, but I wanted to clarify something about Lithium's response to your question...   Only within certain limits. All of the examples Lithium gave were of detuning for a particular reason. Before the engine/turbo/wastegate combination has hit full boost, you can't increase it....the wastegate is shut and the turbo is pushing as hard as it can Once the combination has hit the target (controlled) boost, you generally have full control over whether it makes more or less boost, because it is being limited/reduced from its potential. This is generally done by controlling the wastegate In the top end, with an undersized turbo, it is possible you won't get to your target boost anymore if the turbo is choking up. In this case you cannot increase boost any more without changing the setup. No change in cost compared to any decent build, other than tuning time to get the engine to make less power than it is able to at a certain point
