guys...heh
pardon my ignorance, but i was just wondering, what is the meaning of flat shifting?
im running a exedy brass button clutch and this can take shitloads of power even tho my car's a N/A....
when i tkae off real quick...and rev till almost red line, and change gears, there is always a SNAP kinda sound or response from the gearbox...why is it? its like the stick is snapping out of a gear and into another.
Snap for getting out...but going into the new gear is always just fine.
ne tips to improve take off time? friggin v6 commonwhore could keep up wit me man...and i was pushing her hard....damn...
till i hit the 3rd gear of course...and went thru a flash...i mite not haf a liscence sometime soon but still would love to know these things
doubt the commie drivr would b drivin netime soon too if i lost mine
heh
thanks guys
https://www.sau.com.au/forums/topic/22584-flat-shifting/
Flat shiftiing is when you change gears but don`t take your foot off the accelerator.
Bouncy, bouncy bounce off the rev-limiter with a crap gear change, but if your lightning quick and time the change so that the engine doesn`t have a chance to hit the rev-limiter, you CAN actually add 10kw to your peak power...
...well thats what that Matt-black CRX driving Vanilla Rice geezah told me...
https://www.sau.com.au/forums/topic/22584-flat-shifting/#findComment-484608
yer, change at 6500 and bang it in and let the clutch out as quick as possible.. that way you don't lose as many revs and keeps the turbo nicely spooled up at around 4000rpm or so.. only problem sometimes u can get wheelspin in 2nd or maybe even 3rd which negates some of the benefits of being too quick with it all..
actually, ignore what i just said :) yours is n/a.. but same principles i guess
https://www.sau.com.au/forums/topic/22584-flat-shifting/#findComment-484777
Timmaayy.. Ran a 15.5 in a NA R31 Skyline.. :)
Not to shabby.. It is bad for your driveline however.
He's got a vid(wma/mpg) from the last private AIR drag day. Its some where in the SA section with the results.
I've always flatshifted and this is the first car that hasn't done a gearbox in the first 6 months. I've had it for 2years now and its still flat shifting like never before.. :D My previous VS V8 Manual IRS commodore really didnt like it first cracking the rear irs chassis through one of the diff bolts causing the arse end to drop to the ground then the gearbox soon followed then the diff followed after that. Big $$ spent on repairs.
I don't flat shift in to third as my clutch slips slightly.
That is what has probably saved this gearbox i suppose.
https://www.sau.com.au/forums/topic/22584-flat-shifting/#findComment-485886
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
