I posted up a thread not long ago as well... no one responded...
but I've recently bought a RB25DET alternator for my RB20DET with the plug as well.. I'm planning to install it this weekend...
RB20DET / 70amps
RB25DET / 80amps
RB30ET / 60amps
Edited by johnnilicte
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-3992026
The Nissan US quest minivans (same as the oldsmobile) uses a 110amp (also get 125amp), I stuck that on for my S14RB for all the added voltage load from the dual 20a radiator fans, meth, fuel pump ectr. Cost me $160us for a full recon one shipped from the US to africa,
like so:
Link
Edited by Rezlo
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-3992708
like so:
Link
but then you need to fabricate a bracket for it to fit.
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-3996473
  • 4 years later...
sort of related , my volts on start up are up at 15, and the battery lights on, this could be due to changing from a gtst dash to a gtr dash but even the tuner mentioned it was a bit high,
so do i need to replace the alternator and problem solved?
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-6755341
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
