I posted up a thread not long ago as well... no one responded...
but I've recently bought a RB25DET alternator for my RB20DET with the plug as well.. I'm planning to install it this weekend...
RB20DET / 70amps
RB25DET / 80amps
RB30ET / 60amps
Edited by johnnilicte
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-3992026
The Nissan US quest minivans (same as the oldsmobile) uses a 110amp (also get 125amp), I stuck that on for my S14RB for all the added voltage load from the dual 20a radiator fans, meth, fuel pump ectr. Cost me $160us for a full recon one shipped from the US to africa,
like so:
Link
Edited by Rezlo
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-3992708
like so:
Link
but then you need to fabricate a bracket for it to fit.
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-3996473
  • 4 years later...
sort of related , my volts on start up are up at 15, and the battery lights on, this could be due to changing from a gtst dash to a gtr dash but even the tuner mentioned it was a bit high,
so do i need to replace the alternator and problem solved?
https://www.sau.com.au/forums/topic/225840-altenators/#findComment-6755341
    • Ohh even easier.   Go dial up 700rpm on the hand controller. Rip off the TPS plug, wait till the idle drops and then adjust the IACV screw so it's just a tad below the target on the hand controller (say 650rpm), plug the TPS back in and idle will climb back to target. Done.
    • Hey Sleepergm, I love your inlet piping, do u mind sharing who did the work, please? cheers, Ian
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
