Hey just wondering what fuel pump I should purchase for my R30, my current one is whinging and whirring it's head off and will die pretty damn soon.
Mine has just died again. A long story but now I need another pump. Would an R31/VL RB30 pump fit?????
They sure do fit! They are pretty much identical.
I have even fitted a bosch 044 in the factory position!
Will an R31/VL keep up with my RB20, it has around 165rwkw? or do I bite the bullet and go a 044?
Naturally I want to get out of this as cheap as possible.
If my memory serves me correctly the vl turbo pump is an 070.
Will do the job for an rb20. I just went the 044 so know im not gonna be running short of fuel.
Hi,
the 070, 044 numbers, does the numbers represent litres per minute ?
Nigel
its the last three numbers in the model/part number for that pump.
if its not the last three its the first three but im pretty sure its the last three numbers.
has nothing to do with rate of flow.
my mate has a stock vl pump on his RB30et setup.... pushing 190kW at the rears.... through VLt turbo injectors (270cc i think)
is pretty much maxed out
the R31 pump is an internal one, and the VL one is external.
Vl pumps are cheap at the wreckers, just check the km on the dash before pulling one out of a 380,000km wreck...
also give it a really good flush and clean before useing it... hookup wires and run a few litres of fuel through it into a bucket etc...
it may be worth getting a Repco? Ryco? clear plastic high flowing fuel filter too.... then change it in a month or something to see if its full of residue etc
OR you can get new bosch or walbro units for $150 from bursons etc
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
