Hey just wondering what fuel pump I should purchase for my R30, my current one is whinging and whirring it's head off and will die pretty damn soon.
Mine has just died again. A long story but now I need another pump. Would an R31/VL RB30 pump fit?????
They sure do fit! They are pretty much identical.
I have even fitted a bosch 044 in the factory position!
Will an R31/VL keep up with my RB20, it has around 165rwkw? or do I bite the bullet and go a 044?
Naturally I want to get out of this as cheap as possible.
If my memory serves me correctly the vl turbo pump is an 070.
Will do the job for an rb20. I just went the 044 so know im not gonna be running short of fuel.
Hi,
the 070, 044 numbers, does the numbers represent litres per minute ?
Nigel
its the last three numbers in the model/part number for that pump.
if its not the last three its the first three but im pretty sure its the last three numbers.
has nothing to do with rate of flow.
my mate has a stock vl pump on his RB30et setup.... pushing 190kW at the rears.... through VLt turbo injectors (270cc i think)
is pretty much maxed out
the R31 pump is an internal one, and the VL one is external.
Vl pumps are cheap at the wreckers, just check the km on the dash before pulling one out of a 380,000km wreck...
also give it a really good flush and clean before useing it... hookup wires and run a few litres of fuel through it into a bucket etc...
it may be worth getting a Repco? Ryco? clear plastic high flowing fuel filter too.... then change it in a month or something to see if its full of residue etc
OR you can get new bosch or walbro units for $150 from bursons etc
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
