2 Weeks ago on the Queens birthday i installed my FMIC with thanks to some of the tips posted in this Forum took about 10hrs in total (alot of stuffing around with alignment) but all in all im happy with how it turned out looks pretty sweet and performs alot better than stock
https://www.sau.com.au/forums/topic/225874-installed-fmic/
It was JJ cooling pro s1 , after realising s2 would of cost about $50 extra o well, the price was good for the whole kit.
Cutting the hole was a challange with the wrong tool, ($5 holesaw from supercheap) decided to buy a good one from bunnings $44 so once that was sorted it made things a little eaisier.
After install 2 days later driving along full boost, the stock 90 degree bend (pass side) decided to split right down the seam so i had to pull over & get my dad to come down with tools so we patched it up untill later on replacing it with a silicone bend (one u get from supercheap) and so far so good.
So it was a interesting process but learnt alot from it
https://www.sau.com.au/forums/topic/225874-installed-fmic/#findComment-3977701
yeah i forgot to tighten one of the clamps after i installed my front mount. I upped my boost for a test run, then at peak of 2nd gear, i hear a slight pop then all my warning lights start lighting up, car dies and my steering locks haha. Had to pull over, call my cousin to bring tools so we could remove the front bar again, jack up the car and find the problem...in pitch black darkness coz it was night time lol...not cool.
https://www.sau.com.au/forums/topic/225874-installed-fmic/#findComment-3979195
unfortunately buddy im willing to put money down that if you run any serious boost that cooler piping between the hoses is gonna let go.
ive got a cooling pro cooler and cant wait to get rid of it. its so shit. but then again im running some serious gear, so unless you are to its a great pickup for $345 =D
https://www.sau.com.au/forums/topic/225874-installed-fmic/#findComment-3979201
yeah man im only running 10psi at around 180-190rwkw
im no street racer or track runner just love driving the skyline round town.
Maybe one day when i have heaps of $$$ to spend on a car i will work it to the max
instead got a International Holiday, Morgage, Missus to pay for. On top of that Fuel food Grog Smokes
ahhhhhhhhhhhhhhhhh it never ends
https://www.sau.com.au/forums/topic/225874-installed-fmic/#findComment-3979550
missus to pay for hahaha...
i spend my money on my car...
my missus then has to to spend on me lol
i highly regret buying the greddy cooler that i have...
i'm really wanting to buy an ARC or TRUST return flow cooler now...
patch up that huge hole that i left gaping from underneath the battery tray...
https://www.sau.com.au/forums/topic/225874-installed-fmic/#findComment-3979825
The product is not shit, make another comment towards traders again, expect it to not end nicely. You've done it more than once recently, now is the time to stop and remember the forum rules
JJR gear is PERFECT for the run of the mill application. If your going to spend (on the cheap) $350 for a big end application, expect it not to perform the best.
For a stocker/mild GTS-T, the cooling pro gear is perfect for the application, and priced very appropriately
https://www.sau.com.au/forums/topic/225874-installed-fmic/#findComment-3980065
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
