Hey,
I am looking for the Front Left - ABS Brake Line - Hollow Steel with Screw Nut on the end. - On Turbo R34.
If you have the parts, please pm me or call me on 0401637722.
Kind regards
Christian
Edited by SunnyCoast
hey mate,
thanks for your pm
we can help but need to know exactly which one it is
does it come out of the abs unit or under the wheel arch?
a pic would be great
cheers
hey mate,
thanks for your pm
cheers
If your looking at the ABS UNIT from the front of the car - It comes out of the ABS UNIT "Steel pipe with screw" - (comes out of the FL) abs hole, and runs down the front left side of the chasis (near the air filter) through a grommit and into the front left brake. Its the abs Steel pipe. Not the usual brake pipe, but the abs one. I need the whole pipe, from the unit (with screw) all the way down to its resting place, about 30cm from the brake itself.
Let me know if that helps.
Thank you.
Still looking for the Front Left Metal ABS Brake Line...And it seems i need a new ABS unit also, as i have threaded the line bolt and the unit thread...
Prices on:
Front Left Metal ABS Line (to front left brake) on R34
ABS unit - Big square thing - R34
Would be appreciated as car is not driveable atm.
Thanks
Ă—
Ă—
