ok this has happened to me twice now.
first time was at the bunnings carpark. cruising at like 20, about to turn into a parking spot, then all of the sudden i loose all power. steering locks up, eninge dies, electrics all flick down to accessories mode. i start it up again and proceed into my spot...
second time, approaching a roundabout, coming down from 2nd to 1st, i loose all power again. start it up again and lurch through the roundabout embarased (as you would be) interesting thing is this time i starteed, one of my belts proceeds to scream at me. this usually occurs when its been extremely cold (frost etc) not sure which belt it is, but its damn annoying, did it to me just before outside work.
mind you both these times i had the clutch fully engaged, so its not like i noobly stalled it.
now.
this is really lame. and it wouldnt help that as im writing this i had a shit day at work. but point is. im really getting frustrated of both these problems
any ideas as to what either of these problems might be?
cheers...
Edited by G0DZLR
https://www.sau.com.au/forums/topic/225893-power-loss/
hi i too have had this same problem ony difference is my cars an auto.. just cruising along at around 20km and then car just shuts off.. done it to me one day at a round about then 5 days later it did it 5 times.. touch wood it hasnt done it since but ive asked mechanics and they have no idea what it could be. i had my computer scanned but they found no error codes in it...
would also like some help on this incase it does it again.
jake
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978093
now.
cheers...
In regards to the screeching belt. I have a strong feeling it is your alternator belt, I had the same problem, it is due to the excessive drain on the battery on cold days, therefore making the alternator harder to spin. Check you tentioners or even replace the belt if it looks worn.
In regards to the car stalling (I'm assuming you are applying the brakes when the stalling occurs) - check your brake booster vacum hose (and all other vacum hoses to be on the safe side), there could be a vacum leak or even the brake booster itself. (I had a similar issue in my old Bluebird, however the brake booster diaphram was busted).
just remembered - Also check you AFM (seems to be the problem in quite a few scenarios in previous posts)
Hope this helps.
Cheers
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978210
check your battery etc connections too... i had a similar prob last week over going over the mother of all bumps. thanks dept of main roads...
(also killed a head light bulb)
i forgot to mention, the time i was at bunnings, id just gone over a couple of BRUTAL speed bumps, so maybe thats it. but i think its either that or the AFM, or alternator. either way i think i should get the belts replaced...my cars done 88,000ks, i know that belts get replaced at the 100,000k service, would it be worth getting them done at 90 instead?
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978595
Yeh I had these problems before when I just bought my car. Scared the sh*t out of me because I thought I bought a dud car. Plus it was my first time taking the car out by myself, so when I asked my mates, they thought that I just didn't press the clutch, which obviously I did.
Anyways, it turned out to be the AAC valve. Takes a few hours and straight away the car was running smoother at idle and never stalled again.
On a side note, the link for the AAC valve cleaning should be stickied or something because a lot of people seem to have this issue and not know how to fix it.
Anyways, enjoy.
http://www.skylinesaustralia.com/forums/Di...mp;hl=aac+valve
Edited by mjscar
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3978649
Anyways, enjoy.
thanks for that mate! i may try this as one possibility, couldn't hurt to do it anyway seeing as my car is 14yrs old after all..pitty most of the pics dont work..
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3979175
It doesn't hurt to change the belts a little earlier :D - You get a little peice of mind and the screeching is likely to go away too.
Sometimes it is not the number of Ks the car has done, but the age - as all rubber degrades over time.
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3980365
do you remember which fuse it was that blew?
It was a RED one in the little kick pannel near the steering collum.
It was a fuse for;
Alturnator
revers lights
something
something
something
It ran a bucket load of things.. but have a look, may be worth it.. the huge speed pump may have loosened one of the fuses to which the cor does not agree with..
Edited by GTS4WD
https://www.sau.com.au/forums/topic/225893-power-loss/#findComment-3981479
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
