Hi i was wondering if someone could help me with a boost problem. I recently imported an R34 GTT from japan. Its in good condition with lowish ks (90 000) and runs fairly well when driving normally, however, whenever i try and give it a little more boost than usual it breaks up and starts misfiring, it sounds pretty shit and i loose all my boost. The problem usually kicks in at around 4000 revs. If someone could shed some light on the situation it would be much appreciated, im fairly new to the import scene and this is my first import, its really annoying and i dont really have much of an idea of what it is or how i can fix it.
https://www.sau.com.au/forums/topic/225907-r34-help/
get it tested for a boost leak would be the first place to start.
https://www.sau.com.au/forums/topic/225907-r34-help/#findComment-3978464
If the problem is the coil packs, is it possible for them to deteriorate further, should i aim to replace them as soon as possible and avoid driving. The misfire is also not only limited to boost ive started to notice, sometimes it happens when im driving fairly normally, the car also seems to have a ruff idle. If you guys have any further advice, it would really help.
https://www.sau.com.au/forums/topic/225907-r34-help/#findComment-3980075
Going off your first post where it was only happening at 4000rpm on boost I was going to suggest it is either spark plugs gapped too big, faulty coilpacks, rich and retard, a boost leak ect. ect. ect...
But if you reckon its happening everywhere in the range I would say get new spark plugs first gapped down a little ($30 better than wasting $500 on coills if you dont need em) then if that dosnt solve it change the coilpacks to splitfires. No point piss farting around with tape and glue ect. trying to fix the old ones IMO...I havn't seen anyone cheaper than Croydon Racing either for the splitfires...
In the end though my money is on coils - seems to inflict just about every 34. The splitfires fixed all my issues (though you should be getting a check engine light once they break down real bad - then you can check the fault codes and you should get "ignition"). I had no problem driving around for a few weeks with dodgy coils, car just runs like crap on 5 cylinders (saved a bit of fuel even!)...
Edited by colossus
https://www.sau.com.au/forums/topic/225907-r34-help/#findComment-3980247
Coil packs for sure... i had same problems... got splitfires problem has never returned!!!
I changed plugs first only and was good for 1 day no miss but comes back.
The longer i left it the more often the miss-fire occurred.!!
change ur plugs coz they will be black as!! and get splitfires.... the stock coils are weak don't last long and are expensive!
https://www.sau.com.au/forums/topic/225907-r34-help/#findComment-3982089
Thanks for the additional help guys, im checking the plugs and the coil packs tomorrow, hopefully one of the two will be the problem, not being able to drive the car properly is getting anoying especially as i just got it lol.
https://www.sau.com.au/forums/topic/225907-r34-help/#findComment-3982841
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
