As i said i got defected yesterday and they were good about it but i still need to
change some things around.
My main drama is replace pod or FMIC so i cant be stuffed doing the cooler so i will do the pod
Can someone lend me a stock air box for a couple of days.It needs to be complete if possible.
The rest of the defects i have already fixed..
So if you can help PM, email , sms or ring me on 0437987467
I have a R33 GTSt... :D
Oh yeah im in Berwick so if ya live in Leongatha dont worry about it.....
Cheers
Wayne.... :laugh:
https://www.sau.com.au/forums/topic/225914-been-defected-again/
dats a shame wayne. just curious though did u get done anywhere in berwick?
if you got done im worried about wat would happen to me lol.
tryna stay positive though if u no wat i mean
They got me on Heatherton Rd in Dandy..
Anyway i have what i need ... Thanks guys.. :D
"again"?
how many times has it happened so far?
maybe its time to by the bits so you have them for future defects :D
3 times this year..
But each time they get me for different things..They have never given me major dramas..
Its the first time they have picked on the cooler and pod..
Anyway i have what i need ... Thanks guys.. :(
wayne, I have a 33 airbox, I think I have 2 actually. In ringwood area. I can post if u want or u can pickup....
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
