hi all...
on my way back from an SAU SA cruise tinight, my car started to make a loud humming noise when it hit boost/accellerating
i gave it a pretty hard time tonight, could it be clutch? turbo? thrust bearing?
thanks in advance ppl
https://www.sau.com.au/forums/topic/225928-bad-noise-r33/
Humming as in high pitched? If so and it's only when you hit boost I'd be more inclined to say it's your turbo giving you a death wail :laugh: Able to take off your intake pipe and check for shaft play or any knicks on the blades?
https://www.sau.com.au/forums/topic/225928-bad-noise-r33/#findComment-3978272
haha, a "hum?"
Dozens of moons ago, I had a hum when the motor was partially decelerating. Say 8k RPM and back off... It ended up being the aftermarket ECU was intermittently dropping an injector driver.
If you'd been giving it a hard time, maybe its just uneven wear (therefore balance) on the clutch friction pads... thats a grade A stab in the dark though :laugh:
Better description of location, and or a dyno run with mates listening would be better.
Edited by GeeTR
https://www.sau.com.au/forums/topic/225928-bad-noise-r33/#findComment-3978273
yeah thanks for your input adam..lol
you still defected? good to see SAPOL are still keeping our streets safe/er
Not doing a very good job if "your" still out there. :D
Not long before the Ceffy is back, im really starting to get excited! :)
Shall stop spamming ya thread now... lol.
https://www.sau.com.au/forums/topic/225928-bad-noise-r33/#findComment-3978683
