I have a PWR Water/Air intercooler that I was using with my SR20DET before it blew....
Now that I'm swapping a RB25DET...should I keep it or sell it with the water pump, cooler, reservoir... to get a big front mount?
The Water/Air was good with Ice in the reservoir for 1/4 mile...but was a bit more warm for normal driving...
It was the 5" core X 12" (I think) so the long one with the 2.5" inlet and outlet.
Does anyone here have hear bad or good thing about it (if my goal is 500HP max(at the crank), and will run ~350-400HP daily)
Why not try it on the RB and if you aren't happy then swap it? You may end up costing yourself a bit of cash for no real gain. I know the PWR cores can flow 250-300kw worth of air. GTR cores flow about the same.
The increase in pipe length with the front mount will cause the throttle response to suffer.
It wasn't too hard to install... water pump here, water reservoir there.... and almost no piping! (this change from front mount to water/air was incredible, just cause of the piping lenght, my power band changed a lot! , no more low end torque, but much more top end! I had to dial the cam gear for less overlapping, to get back some low end torque)
I'm not sure, but it's almost sur that it's sold allready, I sold that:
water/air intercooler 16" X 4" > water pump (5year waranty)> Water reservoir aluminium> 2 X cooler 8" X 12" for 1000$ Canadian > almost 1000$ Aus
I would go a large front mounted intercooler. If you've got the money, go for a TRUST twin core...you won't need a triple core unless you're chasing 700hp+. With such a thick intercooler, you may need to use a thinner thermo fan...and a more efficient one to keep your engine bay temps down.
Would be interesting to see how the RB25 goes in the s14. Sounds good! Let me know if there are any major hassles in fitting the engine, as I might be thinking of doing this later too. Even better still, why not go the RB26 in the s14? :P How much will the engine transplant cost? Cos if you're short of $$$ it may be better off modifying the SR20 to reach 500hp...because it's just as equally capable. But then I think the s14 didn't come with the SR20 over there, is that right?
Originally posted by EVOIV
Would be interesting to see how the RB25 goes in the s14. Sounds good! Let me know if there are any major hassles in fitting the engine, as I might be thinking of doing this later too. Even better still, why not go the RB26 in the s14? ;) How much will the engine transplant cost? Cos if you're short of $$$ it may be better off modifying the SR20 to reach 500hp...because it's just as equally capable. But then I think the s14 didn't come with the SR20 over there, is that right?
No RB26..cause it's a bit too $$$ for me right now, worst case if I blow the RB25DET in 2 years, I might put a RB26 back (I will have the trany, the mount...everything ready for it!)
I had a SR20DET before(that I got from Japan...but it lasted 1 year) And all my friend swap their SR20DET once or twice a year (pushing 350 to 400HP) So I want to have something I don't swap all the time, this is why I'm puting a RB25DET in there!
I expect to spend ~ 12 000 $ Can on the swap with upgrade (almost 12 000$ Aus)
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
    • I absolutely love having clean wheels and also totally love cleaning them. Its not as important to me to have a clean car exterior as it is to have clean wheels. So I bought a kit. I generally use different products for my wheels than anything else, so I thought I'd buy a proper kit and bucket to keep it all in. I got this one from Waxit. I also got the CQuartz wheel and plastic ceramic along with a bunch more application micro fibre pads as CQuartz never provide enough.  The kit was good, but as usual the big, long spongey thing didn't fit between my spokes, so I needed to use a detailing brush and a larger brush that I already owned (been doing this forever, the spokes on these wheels are frustrating.) I did a full clean with the wheel cleaner, it has an iron killing product in it, so I found that I could just use the cleaner and nothing else on the wheels. The tyre cleaner and handled brush were awesome. Made cleaning the tyres so easy. Once everything was clean, I decontaminated with isopropyl and applied the ceramic. Two coats. I bought 2 bottles as I have a lot of wheels to do, half of one bottle did two coats on these. The X5 has 20's so I reckon probably 3/4 on that. Then, for possibly the best part, the wheel cleaning kit comes with a tyre black applicator. But, this is possibly the greatest sponge of all time - its a great size, quite stiff and HAS A COVER! When you finish applying the black, you just put the cover back on! This is revolutionary, I normally have to try and find safe places to put my tyre black applicators as they are covered in silicone and tyre crap. Or, you use something which just falls apart. This applicator is the bee's knee's. Get one. It's worth it. The tyre black is also like a cream, its very thick but goes on really thin, its very easy to use with the applicator. Ayway, after a big clean, decontam, ceramic coat and tyre black the wheels went back on and they look awesome.   Thought I'd share.
    • Haha. Good work. I feel some of your pain because I spent a bunch of time under my car over the period too. Probably nowhere near as much as you did. My happiness is similarly improved by obtaining a desired result though. Those side skirts are.....hecking. Very unfriendly for street and hoist. Sounds to me like you've made a cart that needs to be driven up only planks/blocks at a 2 post hoist, rather than trying to get it up onto a 4 poster. It's very pretty, by the way. Somewhat reminiscent of Marty's squid ink on SuperGramps - at least in the photos.
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
