Hey Fellas n gals,
Looking for a local Brisbane / Ipswich Brake distributer. Not sure what pad I would need to take off the shelf to fit my Alcons.
I am going to pull the DS3000's off and need to walk in somewhere and order a set of 'these'.
lol
anyone come highly recomended?
Cheers very much
Michael
(shat my pants when I realised the QR Nissan Shootout is on in a week!!!)
https://www.sau.com.au/forums/topic/225948-brake-pad-distributers-in-qld/
Hey Fellas n gals,
lol
Cheers very much
Michael
wherabouts are you located in Brisbane?
GEt ya finger out Mik, You gtr drivers assume you only have to think about it and it will happen. :D
I get my brembo stuff from Dan at E.R.D. pretty keen prices too but i dont know that he does the alcan stuff. Worth a try tho.
Michael, I get all of my brake components either off Competition Friction or Racebrakes.
http://www.compfriction.com.au/
www.racebrakes.com.au
I have no problems with AP and Brembo and surely they can get Alcon. You will probably need either the brake part number or the dimensions of the pad.
hey chaps,
lol pulled finger out of arse and pulled wheels off and have HEAPS of pad life left. rofl
I spose I should change brake fluid. I think ive done 5 track days on it. Most guys do it every 2nd track day???
Thought my heavy shuddering would have been pads, but must be fluid as pads and rotors look great. Thanks Geoff, Yeah the calliper has a little sticker on it for dimensions of the pads, so grabbed the details off that for the future.
See yas at TimeAttack, hopefully with some sort of stopping power!
Mick
Edited by wrxkilla
I don't see how fluid can cause shuddering?
me either... ! ?
pads and rotors (4 mont old genuine alcon rotors $700 each) :blush: look fine to me and look smooth.
trying to figure why i was short of brakes (alot of pedal travel) and getting some shuddering...
any ideas fellas?
me either... ! ?
pads and rotors (4 mont old genuine alcon rotors $700 each) :) look fine to me and look smooth.
any ideas fellas?
Get your rotors machined. Looks can be decieving. If they are even slightly warped your brakes will shudder.
The other area to check is your steering. play in the system wont neccessarily show up on acceleration or cruise but can get up a fair wobble under brakes.
cheers fellas,
doing some searching under the brakes section of the forum. some decent threads actually.
ah well, will look at it after timeattack... lol
As long as it sops for now....
any ideas fellas?
if you have excessive pedal travel you may have boiled your brake fluid, which means it could do with a drain and refill and a bleed, not expensive and it cant hurt.
If you have shuddering then it is likely the pads aren't bedded properly anymore, that you may have warped them or most likely you have stopped hard after some serious brake workout and left the car sitting, maybe even with the handbrake on. This last can change the rate of cooling and you get pad material entering the disc grain structure as it cools leaving an area that is harder than the surrounding metal. This is far more common than just warping and is almost impossible to remove with a quick skim. Look for a different colour and a pad outline on the disc surface.
So is the shuddering front or rear?
When bleeding try to never allow the reservoir to drain completely. Almost drain it through normal bleeding then top up with the new fluid and continue until you get clean fluid of the new colour through. I use a hands free bleeder and can do the brakes in around an hour including wheels removed for inspection of all other components.
BTW just ordered a set of Ferodo DS2500 pads for the GTR33 (stock Brembo) for $272 front and $161 rear and delivered fast From Competition Friction. I'm certain last time was overnight.
Be interesting to see what they can do for the 380mm x 40mm AP racing calipers (FIA GT1 class caliper) I just bought. :D
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
