FYI
We sold a set of HSD HR series coilovers to one of our customers who drives an EVO. This resulted in his PB tumbling by over 1 second around the Queensland Raceway Sprint circuit to do a 57.7 second lap!!
Think about what these coilovers can do for your car! :D
Got anything else you want to sell? :D
at least now we can share this information, and then more people know what to expect from HSD coilovers, rather than only knowing by speaking to someone who has first hand experience.
wow! 2k for a whole second!
so where's the other half of the story? mods, experience, track condition, alignment changes, tyres still the same etc etc
Kinda useless if it was their second time at the track don't you think?
lol I love you guys.
Gavin has been getting out there on the track for around 2 years now, and this is about his 6th track day with the EVO. the coilovers was the only change he made to the car to achieve his new PB.
and LESS than 2K for more than a second is a HUGE improvement for those who actually know what they are talking about.
PS whats dog poo going for these days? ;)
I love how you imply i don't know what i'm talking about after you have clarified that he isn't a track newbie and so actually validating my point....
righto...
So he fitted new springs and shocks (Evo's have coil overs standard) and DIDN'T CHANGE THE WHEEL ALIGNMENT :P
Cheers
Gary
So he fitted new springs and shocks (Evo's have coil overs standard) and DIDN'T CHANGE THE WHEEL ALIGNMENT :D
Cheers
Gary
that I cant tell you Gary. whats with all the negative posts? After all, I am a track whore too, and was a long term customer of AMEC, before I bought it. now I am a poor track whore lol.
welcome to SAU...its a haven for glass half empty people.
thanks for sharing your findings with us...next time i don't think you will bother.
Edited by DiRTgarage
That wasn't a negative post, I was just curious as to whether the alignment was altered after such a major change to the suspension. If the alignment had been changed then it would have contributed to the result. If the alignment hadn't been changed, then there is more potential in there to be found.
As for the real negative posts, I think it stems from incomplete information that some readers would like to know. Especially if they are truly interested in finding out if the result is in fact a good one or a bad one. An example perhaps, based on past experiences I could do a track wheel alignment on an Evo 4/5/6 and find a second a lap, that's good value for $100 in labour plus a few $low value parts. Or I could fit a pair of swaybars and pick up clsoe to 2 seconds, that's even better value for $500 and an hour's fitting.
So back to my original post, for $2K the 1 sec improvement is not good value if the alignment has be optimised, but it's not that bad a value if the alignment is still unsorted.
Cheers
Gary
Cheers
Gary
I spoke to Gav on the day he set his PB, when i asked him what he'd changed since last time he just said the HSD's, he didn't offer if he'd changed any alignment settings specifically.
I certainly hope he did cause there's little hope of me catching him now if he hasn't.
Sounds like i need to bite the bullet Gary and fit your track kit for my S13 :) . I think i've gotten all there is to get out of my HKS stuff.
Edited by Simonster
Cheers
Gary
I can find out if Gavin had a wheel alignment or corner balance done to satisfy those after more information. I can also find out what sneakers he was wearing too :miner:
Just curious, which track are you referring to, picking up 2 seconds by fitting a set of swaybars. QR sprint circuit is a comparatively short circuit compared to say Eastern Creek.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
