There I was driving down Leach highway last night around 5:30 and amongst the traffic was this bombed rex. White with GT wing (missing but had the boot clips), blue roll cage, carbon bonnet, sounded awesome. Then along came an R33 GTR, white with gold rims, plates GTR 300kw. Both seemed ready for a bit of fun.
The only problem...... I was in the soarer!!!!!!!! :) ha ha ha
Anyone know who owns the GTR? Looked really nice and I'm guessing by the plates has had some work done to it??
Brett
https://www.sau.com.au/forums/topic/22599-always-the-way/
Shuto, it is loud and comfy but pretty slow compared to my car..
Dan, yep those were the plates, damn nice car..
Red17, it's not the Le Mans one for sale is it? That is the only one in WA, $68k and it is in the first HPI GTR special.
Paul, I'm guessing it has around 300kw's, so it would be a good run.
https://www.sau.com.au/forums/topic/22599-always-the-way/#findComment-486547
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
