new job, new car = what do i do now
Guest 33GTS25
as the title above states, i have a new job and part of salary package includes $20 k.p.a towards a car, so i am off to buy a bimmer and 33GTS25 becomes my project.
end goal is that 33GTS25 will deliver 500 rwkw and will become saturday night special as well as hard core drag car, or should i say that the object is to build a streetable drag car that runs on pump fuel, i realise that this may be a big ask, but have the time and money to achieve my goal :twisted:
so where do i start and what bits should i be buying
i am going to build a full in-house motor etc so want some ideas from those in the know
my thoughts
start with RB30 block
then i can probably pick it up from commode driver for $100 and send it to be acid dipped and cracked tested, if it has any flaws, well at least it has only cost me the $100 i.e better than buying R33 half cut and finding it has got problems.
where i should go from here is something i would like to hear about
as i said before, i want it streetable so a grout filled block is out of the question
rod
https://www.sau.com.au/forums/topic/226-new-job-new-car-what-do-i-do-now/
If you are serious. I would forget what you read an go out and buy an rb26. get it recoed with either N1 pistons or forgies if you the budget agrees. put some 272 cams in and twin 2540R turbos or a t78 and your done big cooler power fc rb25 det gearbox metal head gasket, and spend some cash on good drag suspension.
it will run all day on a set up like that.
meggala
a good rb25/30 will cost you 10 15 k easy and they arent as reliable.
there is a guy in qld with a r32gtst withan rb26 and he runs 11's woith only boost.
Guest 33GTS25
jimbo, 500rwkw!! i have a friend who has an xc falcon running 500rwkw from a 460 that has been stroked to 484 and no matter how many magazines i show him, he still doesn't think an equivalent powered 6 could take him but aside from that i love big hp cars
birty, unfortunately no M or Z cars or even a GTR which i also considered, the car is for business purposes i.e taking high net wealth clients to golf etc so a four door is necessary, can you imagine putting jamie packer in the back seat of a GTR. i dont think he would be too impressed, actually i am looking at either a 5 series or short wheelbased 7 series
meggala, the Rb26 sounds like a better option from your comments,
how much work would i need for my power goals i.e would i still need to crack test the block etc. should i purchase an HKS crank to go with the N1 pistons etc etc
this is the first time i have built a full in house motor and the process means that i will be probably bothering you guys a whole lot more from now on
thanks for your help
rod
www.justjap.com
www.japimports.com.au
www.adelaidejap.com.au
www.japanesemotorsport.com.au
Also give Mr GTR a call he had one from a 34 last time i was there
Mr GT-R Australia Pty Ltd
SKYLINE SPECIALISTS
ABN 93 094 156 699
P.O. Box 801, Oxenford
Queensland. 4210. Australia.
Ph / Fax: +61 7 5573 5734
Email: [email protected]
start at takahira.com for the stroker cranks etc .
ifyou want 800 hp at the fly mario did that on stock internals on a gtr.
just get an rb26 from an r33 or later and get it properly built with forgies -t88 etc.
btw I know of an r33 gtst with an rb26 for sale it has dog box line locker all kinds of stuff mail me if you want ot know more talking 30 k or minus 5 not sure of the price.
meggala
Guest 33GTS25
thanks meggala, 800hp at the fly on stock internals!!! geeze thats pretty damn impressive, well that sounds a whole lot cheaper than my previous option. i think that once the process begins i will be in your ear a fair bit for some tips on cooler size and what parts i should be getting etc.
it also helps that my fiancees father is a nissan mechanic so i can get the work done for a carton of XXXX not to mention the discount i can get on other bits from mates
stay tuned folks 33GTS25 project due to start from 1 july
damn i am going to miss the sound generated by the N/A though!!
rod
hehehehehe!! takakaira com is a great site isn't it. Did you check out the sequential shifter! i'd love one of those. Project car sounds great, there are several ways to go all expensive, if I where you i'd spend some more time on research and planning befor I jumped into spending although I know from experience the urge to get started is almost irrisistable
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
