Falcon is a humorous term in sport describing an accidental knock to the head by sports equipment.
en.wikipedia.org/wiki/Falcon (sport)
Hardly a falcon my ass...
Cling desperately to it cos its all you've got till we hand you your arses again next year. :D
  • Replies 90
What about the blue dude who took a hip to the head?
Didn't wanna bring it up, but he dropped like a sack of shit :D
I'll second that!!!! arent you guys glad you had your forum crashed by queenslanders!!! there always next year... [isnt that what second place always says!!!!]
Bit like the Vic Fags when an interstate team wins their precious GAYFL final. Suddenly don't want to know about it :rofl:
Had to laugh, every time a bit of a tough tackle was put on all the nearest 'roaches would pile in, but fark what a bunch limpwrists they were. Looked like they were fluffing pillows instead of trying to start a barney. And Mason is like this big sook who tries to be the hard man, but when he can't dominate he turns to putty and starts looking for a little guy to try to crunch. Do us a favour and send him of to be with Hopoate.
Yep couldn't agree more,,,the lazy turb,,,impact player my arse. After his 1st hit up he hid 10 metres behind the ruck with his hands on his knees puffing like a bloody billy goat. Just shows you Easts have way to much money and no brains. The only impact that over-rated clown makes is up the Cross at 3am with his bum-chum mate Gasnier. Maybe union would take them as a package deal.
Neil.
Sorry Jase,,, did I miss something,,,are you telling me the Roosters are close to the top because of Mason and your sure not telling me the greatest football team that ever played has to rely on always injured Gasnier,,,REG yes ,,,Mark NO. I'll have 2 Coopers any day.
Neil.
Sorry Neil, Rugby will not be taking any more overpaid has-beens from League if I can have any persuasion. Your leaguie forwards are too soft and won't understand rucks and mauls, let alone a line-out or a contested scrum or work rate or mobility combined together, your centres will not have the situational awareness to play anywhere but at fullback or wing and your backs and wingers will then have to comb their hairdos elsewhere. Did I miss anyone else who can't count beyond 5.....0, 1, 2, 3, 4, 5, last....(apply kick or be scorned by Sterlo the Flog) :)
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
