Wrecking 1995 Manual R33 Turbo Coupe
Might as well just upgrade to a SVS D6000... I think if it goes down to $1.5 to $1.6k I'm going to do it... Will work out which part of the couch I'm allowed to sleep on once I'm banned from the bedroom. Same, however technology changes and these days those once amazing subs are just mediocre compared to a SVS, Velodyne and now (apparently) Tonewinner. They're always closed, treble performance drops and I notice the speakers fall off axis quite easily. Compromise right? I ran the room calibration with the door closed etc. and you could tell the room EQ correction slapped on more mid and treble. With Yamaha's YPAO, you can't see what has been applied to the EQ with correction applied, where as the older Audessey it showed you the post correction EQ. -
That sounds pretty good. I saw them play at work, once. They were pretty good. One of the band members was slightly inebriated and throw a t-shirt merch box into the crowd. After their set, they tried to recoup the t-shirts or payment. Was funny and sad at the same time.
And these are the fronts I'm using, they don't look like much but performer better than the previous Tannoy MX3 and the Wharfdale Modus 5. -
Clean set up. Do you notice any impact with the doors sitting out in front? (If/when you get time to listen)
