Hey guys.
After 4 years of driving as a daily it's finally time to pull the rb out and see how it's going.
The timing belt tension was not right when it was replaced a while back and it seems to have worn the crank gear and thrown out cam timing.
Even after the belt was retensioned it skipped again and ended up 3 teeth out on both cams when crank was at TDC.
It felt like a really laggy car when this happened and slow. Top end rpm and peak power wasn't affected, but I had barely any vacuum on the gauge at idle due to the slipped belt.
To add to that, the harmonic balancer has seized on the crank due to the bolt being loose. The key and keyways are still lined up though.
Will pull it off when I put some dry ice in the front of crank and heat up balancer.
Engine is still stock internally other than cams, so it will be interesting to see how it's going inside. It has and engine number that is common with r33 GTR engine serial, so I'm hoping it's the wide oil pump drive crank.
Build up will be mostly stock as it's a daily driver, so new stock pistons, rings, rods will stay. Stronger fasteners and metal gaskets will be used though.
Guess I'll find out when I pull it apart and see what condition it's in.
As you can see space is precious.
I'll post pictures as I go.
Cheers.
post-12712-1214732612_thumb.jpgpost-12712-1214732651_thumb.jpgpost-22439-1122995437.jpgpost-12712-1214732716_thumb.jpgpost-12712-1214732743_thumb.jpgpost-12712-1214732780_thumb.jpgpost-12712-1214732827_thumb.jpg
https://www.sau.com.au/forums/topic/226012-engine-out/
  • Replies 109
True, not a bad idea to throw a set of slightly tougher pistons in with stock rods. Would be good for a bit more power without costing much more than stock replacements would.
Either way though will be watching thread with interest :D Good luck!!
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3980443
Good point about pistons.
I try not to do short trips in this car so maybe I just might bite the bullet and go forged.
It was putting out 352Rwkw with stock bottom end so I just need to find a piston that can run tight skirt to bore clearance and stock rings. Just don't want a slapper.
I have read other posts and CP/ARIAS etc seem to be the go, but any input would be great.
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3980646
Arrr dam sean i need to drop my GTR off there for a few weeks so you can fit the dumps to my Turbos :). Hope all go's well.
Ha ha cheers. Yeah had plenty of practice pulling and swapping turbos in GTR's lol.
Hows your forged engine going?
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3982114
ACL race seies make a great street forged piston. Nice thick top rings to provide a good bore seal to prevent blow-by.
Looked em up a while back, you're on the money.
Can stock rings be fitted?
Cheers
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3982118
just curious, how long did it take 2 pull engine out? goodluck with rebuild
First time for me so all up it took me nearly 10 hours total with me working on it.
Pain in the proverbial.
A few pointers, I separated g box and left the prop shaft to the front diff in as I couldn't get the shaft nuts undone.
This meant that I had to remove both engine mounts to clear the crossmember.
I forgot about the power steering connector lol.
Front right drive shaft, I pulled the front diff cover off to lever the cv shaft out of the spider gear.
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3983021
Any more details with plans for the motor?
Aiming for an engine that is good for street, drag, and touring with no more than 8500rpm and 550-600 hp at the crank.
It was already making 352Rwkw on 17 psi.
I prefer to do this now than when it fails due to something else (piston or spun bearing etc) and cost goes up.
Still sorting out what to do.
But so far plans are:
Disassemble and inspect condition of internals, and clearances.
clean inspect and machine block
Tomei metal gasket kit and 1mm head gasket (8.7:1 comp ratio)
nissan gasket kit
Forged pistons ACL? 86.5mm
stock rings oversize
nissan or N1 bearings
stock rods with tomei bolts
Arp head and cradle fasteners
sump baffle kit
head oil restrictor
new oil pump N1?
inspect and rebuild head
valve guides
stem seals
new n1 springs
port match and cleanup
Edited by GTRsean
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3983044
I've been advised that the "nissan gasket kit" does not include all of the gaskets but to instead get an ACL kit as it includes everything.
Also instead of using stock rods with tomei bolts why dont u buy some second hand shot peened rods with arp bolts for about $300 (in the forsale section often).
Also get a "100,000km service kit" for about $450 which has the idle bearings, timing belt, cam seals and n1 water pump - cheaper than buying it all seperate.
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3984066
nissan gasket kit
sump baffle kit
head oil restrictor
new oil pump N1?
valve guides
stem seals
new n1 springs
Cheers for the info! I like this for a change - a good streetable rebuild. Most are completely insane 400+kW builds but this seems like something that's easier to live with.
Your wallet probably loves you right now.
You're happy to leave factory rods in there? I'm with Ben on this one :(
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3984137
The gaskets in aftermarket sets suck the big ones. Buy a genuine Nissan exhaust manifold gasket and any engine oil seals you're changing.
Not looking forward to getting the replacement seals, gaskets etc!!
I have already got idler and tensioner bearings from CBC in Eastern Creek a while back.
Have a new gates belt too.
Looking st getting Tomei 1.0mm headgasket and inlet, throttle body, exhaust steel gasket set from Hi Octane.
https://www.sau.com.au/forums/topic/226012-engine-out/#findComment-3984615
Guest
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
