I've been advised that the "nissan gasket kit" does not include all of the gaskets but to instead get an ACL kit as it includes everything.
Also instead of using stock rods with tomei bolts why dont u buy some second hand shot peened rods with arp bolts for about $300 (in the forsale section often).
Also get a "100,000km service kit" for about $450 which has the idle bearings, timing belt, cam seals and n1 water pump - cheaper than buying it all seperate.
Hmm, sounds like a plan. Anyone got a set of stock rods with ARPs ready to get rid of!! Got the money ready!!!
Spool/Eagle H beams are apparently around 100 grams lighter each than stockers, less rotating weight??
  • Replies 109
Okay, pulled more parts off today.
Started with harmonic balancer which was seized on the crank due to bolt being loose.
Poured boiling water on the balancer and tried pulling it off. It came off : ).
The belt had not slipped like I wrote earlier, the crank, cam drive gear had sheared the key in the keyway and was slipping that way.
Crank should be okay to clean up as the keyways are still okay.(Will find out if it's an R33 engine for sure after checking oil pump drive fingers crossed)
All the intake manifold and throttle bodies came of easy enough. Everything got marked so I don't mix em up.
All of the water, vac pipes will get changed too (never avoid changing hoses!). AAC valve was in fair nick, but it'll get cleaned up too.
post-12712-1214899332_thumb.jpgpost-12712-1214899354_thumb.jpgpost-22439-1122995437.jpgpost-12712-1214899412_thumb.jpg
Edited by GTRsean
Mate, Spool rods are the go and come with ARP bolts. The lighter you can make your engine's rotating components (without compromising strength) the better. They're bloody good value too, especially when you compare the cost of prepping old rods with new bolts. It's just not worth the effort.
Hmm, true that one. I want lighter but stronger internals..
Cheers for your input :P
Just pulled off everything except for crank and cradle.
Not too happy with what I found with cylinders 4, 5 and especially #6 piston. It was doing great to still be running ok.
They look like something has been in there judging by the score marks and pitting/chips on pistons.
Pistons have no busted ring lands and no broken rings
Reading the engine failure thread ages ago, I'll assume in it's last home it blew a rear stock ceramic turbo and sucked in some crap... Maybe.
When I bought the car it had R33 N1's since it was imported, now running 2530's.
Engine is complete stock internals, 86mm bore so I will get it taken out to 86.5MM (20 thou over). scoring is around 8 thou deep on worst areas.
Bearings are in good nick, no picking up or scoring, they were stock nissan too. Crank big end journals were smooth and no scoring. I'll pull the crank out tomorrow.
Anyway here's the pics:
My work space...just one carport is mine!post-12712-1214926296_thumb.jpgpost-12712-1214926343_thumb.jpg[
tta
hment=168899:head_yo.JPG]post-12712-1214926429_thumb.jpg #1post-12712-1214926482_thumb.jpg #2post-12712-1214926528_thumb.jpg
Edited by GTRsean
Ouch not so nice Sean owell some new rods and pistons sould have this beast singing!
True lol. Amazed it ran ok for so long!
Pulling out oil squirters, the bolts have a valve and spring inside and seem to only open when engine oil pressure is high enough!!Mad engineering.
Block is bare now, cleaned it and wrapped in gladwrap ready for machining. 86.5mm should clean it up nicely.
Checked the crank and bearings for damage/wear and thrust and all seems to be great for the use and abuse it had/has taken.
Measured mains and big end journals, big ends are all the same measurement. No out of round issues either.
Now I have to choose between ACL race series bearings, or Nissan bearings. I compared an ACL to a nissan shell and they look almost identical.
I'll put it down to what I can get easier. I've heard and been told the ACL's work well.
The R32 and R33 GTR engines have a few differences in regards to colour coding on bearings, as I have the R32 workshop manual. Just going off the markings on shells.
Crank is a long pump drive(r33) and oil pump is good.
The crank cam gear keyway will need to be welded and machined as it's stuffed.
Edited by GTRsean
Pic of oil pump disassembled. Screws were locktited.
Oil pump on the right is from the engine (r33 95 model).
Oil pump on the left is an old N1? pump I had lying around. It has slightly wider gears, less teeth and a different internal design and more screws for cover.
Gonna see how much billet gears will cost to get made just for curiosity sake.
A new pump will be used either way.
it's amazing how different the pumps are in the internal design. i love all the peolpe who always said N1 pumps were exactly the same except for a high tension relief spring...
good to see you getting stuck in mate. :D
Cheers R.
Yeah the gear outside diameter is bigger too as well as wider.
Here's some pics of the main and bigend bearings. Mains are Green (standard 5 bearings).
Good Luck with the build Sean :D
I have just done a freshen up with mine
How did you find the turbo upgrade before the engine came out..from the N1's to the 2530's..your dyno figure is awesome and I am looking for the same sort of power figure but dont want laggy turbos to get me there..
Good Luck with the build Sean :stupid:
Hey Sinful,
Nice to know that your engine is fresh aye :D
Yeah, the r33 N1s were great for a bush bearing turbo and when I first got the car it put out 296RWKW on 18PSI.
Put the 2530's on and at first they were a little slower to come on, but with poncams and tune it is a great street car. Very sensitive to cam timing these 26 engines are!. The 2530's make the same power with less boost. When this engine is done we'll see what the response and drivability is like, I can't wait.
Edited by GTRsean
Ah Nice work buddy, youre doing well with the space you have and good on you for doing heaps of it yourself.
Piston damage isnt too bad, not as bad as having half of your ring gone and the others in half! and the engine ran fine! apart from blue smoke sometimes...
Will you assemble the engine or are you having someone do it for you?
P.S The car is being sprayed in a couple of weeks. Its running and driving now :stupid:
P.S The car is being sprayed in a couple of weeks. Its running and driving now :)
Nice to hear it's on the road! Should look mad when it's done.
Yeah, space is a premium and lots of storage boxes are my friend.
Gonna get block cleaned crack tested and bored, honed then build it up myself. Clearances and keeping it all spotless is what it's all about :).
I'll take my time doing this build and have to save more dough up!
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
