  • Replies 109
Ha ha. All done!!!! YAY!!!
Finished off all the little crappy stuff in the engine bay and under the car then at 4:30pm finally ran it on the starter to get oil flowing. Could hear every cylinder, nice.
Then started it for real, fired into life after 3 seconds : )
Drove to the servo and loaded it up on the way there and back, with the waste gates free so no boost to help bed in rings.
Came back, dropped the oil and put more mineral oil in and changed filter and hooked waste gate rods back up. Went for another drive, nice! Good to be driving her again.
Only problem may be that I need a new idle control valve :( as the engine revs (flares) by itself continuously at idle.
Sounds throatier than before too.
Cheers
Thanks :(. In the end I think I owe myself 5K+ lol. Great experience, and knowing the fact you built it yourself!
Well, on the stock bottom end it was putting out 350RWKW on 17psi. So I'd be happy with the same amount (read 500hp atw). Mainly due to he stock gearbox, and I built it to handle the power reliably without worrying about what the bottom end is like.
Went for a drive tonight, and it's really smooth and sounds gutsy lol. I'm only taking it to 4500 to 5000 at the moment at part throttle. Put 110k on it lol.
I'll book it in for a tune once it's got some kays under the belt........we'll see.
great work sean!
looks nice. and i love ur display pic. car looks smooooth as!
cant wait to see the dyno results. sounds promising!
Cheers. They really like taking your money lol.
Unplug it. Need to meet up for a cruz soon when i get my car back.
I'll try it out Brad. I also need to make another dummy load for the hicas solenoid I pulled out of the engine bay to stop the computer thinking theres a fault.
Cruise, for sure. I'll do the Putty cruise in October now :banana:.
Damn Sean, very nice and very fast work - fkn great effort!!
going to bug you for a ride in it soon if i get a night out i'll bring the SLR and take some shots!
Thanks Chris. The engine covers you did for me look awsome with the polished stuff so kudos to you. When we get a chance (read time off from busy schedule) for sure.
unreal sean. ive booked the gtr in for tune weekend after the long weekend at uni group. so will all have to go for cruise very soon. i just need front bumper now!!!!!!!!!!!
I'm glad it's done. Now done over 200k, and it's smooth as. Will be great when you get yours tuned.
I'd also like to thank everyone who gave some advice and imput on how to go about doing this project. 3 months seemed forever to me but it was pretty quick in the end.
Okay! Put 1200km on it so far, changed oil and filter again at 1000k and check up and tune on dyno is booked for tomorrow morning (only good thing about shift work lol). Gonna check a/f ratios etc, to make sure it's happy when I use the upper end of the rev range :P .
It has a pretty beaty, cammy idle, only using 12psi to be safe lol. I guess I'll have to check nuts and bolts are tight too etc. Twin plate clutch is great compared to the triple I had for the street.
Also the engine has no slap or rattles when started and warming up. Engine builder I took the block and pistons to, recommended running piston to bore clearance at 3.5thou so I'm happy.
Edited by GTRsean
Congratulation Sean..
Amazing how quick the build was done mate specially with work space..
Looking forward to updates.
Cheers :(
Okay, got it dynoed and cleaned up this morning. Found a couple of things. The fuel reg might need changing as it's a bit sus when revs are high at full load, more fuel was added to compensate but not too bad as it's on min 11 PSI boost anyway. Ordered in one from nissan. It idles at 1400RPM, idle control valve is letting too much air through(o ring inside is non existant), and I cleaned the throttles :D even though I read a topic about not to do that years ago!! It takes the sealing coating off the inside of the butterfly to bore seal.
Other than that, all good and since cam timing is sweet the gaph is great. It'll go back to the dyno in 2000km to get a high boost tune lol.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
