Cheers Thomas,
Not a lot of room thats for sure.
Yep, just waiting for some valve shims and other stuff to come in from Japan ordered through nissan Blacktown.
Can't wait to get her on the road!!
Should be the longer drive on yours, get back to us on what you find. My engine was out of an R33 GTR by the engine number as it was changed before it came to Aus I'm sure.
I was going to go a fresh set of stock pistons, rings, bearings originally, or just the forged standard size pistons to freshen up till I found the scores.
Bore and hone cost $350 (sort of a favour) thats why I got away with keeping costs down, head skimed, cleaned etc $90. All the rest, done myself.
The hardest thing is not spending more money on crap you didn't put in your goal, budget. It really can snowball, gotta draw the line somewhere lol.
Edited by GTRsean
  • Replies 109
Cheers Thomas,
Hey Sean..
Hopefully I find out about that drive sometime this week.
Definately know where your coming from about drawing the line.. Like I said same situation as you were in a few weeks ago.. Yet to open her and decide what needs to be done all pending on condition..
Cheers Tomek
coming along nicely! :P cant wait to start on mine..
as for the budget thing here's my story.. was going to put the n1 motor i bought straight in.. took 5 months to get here so i started buying bits and pieces.
then when the motor arrived i was told to pull it down to inspect, which moved me towards a full rebuild, lucky as there are some small scores up and down the bores on most cylinders, so a rebuild was a must.
hopefully will finish up under 10k haha
Cheers Andrew.
Wish I had an N1 block lol, nah, not for my application :(
Scores in the bores?, how deep are they?. It would be nice if they disappeared with a light hone would be nice, but I guess you will take it out to 86.5?
  • 3 weeks later...
Nearly there!
match ported manifolds while they were out.
New shims to do valve clearances.
Bolting up as much as I can before it goes back in.
Craved is nearly finished. Loving his work.
Nope. I'm happy with what I put in it. I'll kick myself hard later, but N1 pumps go ok.
Still have to find out what housing I have here, that I was going to put the billet gears in and use in the engine. It's not an N1 pump so I didn't use it due to being unsure of what I had. Still don't know, no one knows.
The one on the left. No idea?????
Have I lost anyone lol.
Tomoz morning is the plan.
The other thing I did the other day was setup and adjust the inline throttle setup. Completed that in accordance with the manual, and it's pretty easy after you read it like 5 times lol. Nice and smooth and all good.
There was a couple o little things this arvo to get done before she goes in, like fit the balancer and torque to 350,000 foot pounds lol. And fish out a washer I dropped down the front cover GRRRRRRRRR! It's out phew.
Got covers off Craved today :P:P .
The guys who spotted the covers in the shed were blown away lol, no complaints here lol.
Engine bays is a bit neater.
Just befor balancer was fitted.
Edited by GTRsean
Thanks Brad!
What a long day. Tired and got a headache.
Had to improvise with no chain for the engine crane this morning, (mate borrowed it a month ago).
Twin plate clutch was the first thing to go on this morning.
Cracked the s#%ts with crawling under the bloody thing later in the day. :D
Had a mate help me but had not much experience, so I'll be finishing up tomorrow.
To do tomorrow:
Bolt up gbox x member
Fit center tailshaft bearing mount
Fit a couple of belts and fan
CAS sensor
wiring
pipework
front suspension top nuts
gear shifter
Fill up oil, and do up sump plug!
Fill front diff.
Fill power steering
Coolant and bleed
Crank over, then start!
Bed in engine. ;)
Guest
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
