  • Replies 109
Ha ha. All done!!!! YAY!!!
Finished off all the little crappy stuff in the engine bay and under the car then at 4:30pm finally ran it on the starter to get oil flowing. Could hear every cylinder, nice.
Then started it for real, fired into life after 3 seconds : )
Drove to the servo and loaded it up on the way there and back, with the waste gates free so no boost to help bed in rings.
Came back, dropped the oil and put more mineral oil in and changed filter and hooked waste gate rods back up. Went for another drive, nice! Good to be driving her again.
Only problem may be that I need a new idle control valve :( as the engine revs (flares) by itself continuously at idle.
Sounds throatier than before too.
Cheers
Thanks :(. In the end I think I owe myself 5K+ lol. Great experience, and knowing the fact you built it yourself!
Well, on the stock bottom end it was putting out 350RWKW on 17psi. So I'd be happy with the same amount (read 500hp atw). Mainly due to he stock gearbox, and I built it to handle the power reliably without worrying about what the bottom end is like.
Went for a drive tonight, and it's really smooth and sounds gutsy lol. I'm only taking it to 4500 to 5000 at the moment at part throttle. Put 110k on it lol.
I'll book it in for a tune once it's got some kays under the belt........we'll see.
great work sean!
looks nice. and i love ur display pic. car looks smooooth as!
cant wait to see the dyno results. sounds promising!
Cheers. They really like taking your money lol.
Unplug it. Need to meet up for a cruz soon when i get my car back.
I'll try it out Brad. I also need to make another dummy load for the hicas solenoid I pulled out of the engine bay to stop the computer thinking theres a fault.
Cruise, for sure. I'll do the Putty cruise in October now :banana:.
Damn Sean, very nice and very fast work - fkn great effort!!
going to bug you for a ride in it soon if i get a night out i'll bring the SLR and take some shots!
Thanks Chris. The engine covers you did for me look awsome with the polished stuff so kudos to you. When we get a chance (read time off from busy schedule) for sure.
unreal sean. ive booked the gtr in for tune weekend after the long weekend at uni group. so will all have to go for cruise very soon. i just need front bumper now!!!!!!!!!!!
I'm glad it's done. Now done over 200k, and it's smooth as. Will be great when you get yours tuned.
I'd also like to thank everyone who gave some advice and imput on how to go about doing this project. 3 months seemed forever to me but it was pretty quick in the end.
Okay! Put 1200km on it so far, changed oil and filter again at 1000k and check up and tune on dyno is booked for tomorrow morning (only good thing about shift work lol). Gonna check a/f ratios etc, to make sure it's happy when I use the upper end of the rev range :P .
It has a pretty beaty, cammy idle, only using 12psi to be safe lol. I guess I'll have to check nuts and bolts are tight too etc. Twin plate clutch is great compared to the triple I had for the street.
Also the engine has no slap or rattles when started and warming up. Engine builder I took the block and pistons to, recommended running piston to bore clearance at 3.5thou so I'm happy.
Edited by GTRsean
Congratulation Sean..
Amazing how quick the build was done mate specially with work space..
Looking forward to updates.
Cheers :(
Okay, got it dynoed and cleaned up this morning. Found a couple of things. The fuel reg might need changing as it's a bit sus when revs are high at full load, more fuel was added to compensate but not too bad as it's on min 11 PSI boost anyway. Ordered in one from nissan. It idles at 1400RPM, idle control valve is letting too much air through(o ring inside is non existant), and I cleaned the throttles :D even though I read a topic about not to do that years ago!! It takes the sealing coating off the inside of the butterfly to bore seal.
Other than that, all good and since cam timing is sweet the gaph is great. It'll go back to the dyno in 2000km to get a high boost tune lol.
Guest
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
