Hey guys
hoping i can get some help. I have done a search but havnt found anything.
I have recently done a manual conversion on my 4 door 32, but now i want to wire up the reverse lights. I know that i have to conncet the 2 wires off the box to a plug somwhere in the engine bay.
im hoping to do this tomorrow on my day off.
Any help is MUCH appreciated!
Cheers Josh
heya josh, do a search on google for a pdf file for the R32 technicians service manual as it has all the wiring diagrams on it.
how ever the plugs for all the gearbox loom blugs in by the fuse box, theres a reddy brown coloured plug that was used for the auto box, it should be there.
Yip
theres 3 sets of connectors right next to the fuse box. They are attached to the strut tower.. Its the bottom one.. it has a total of 8 wires - 2 by 4
You may also need part of a manual harness to mate up to the auto part of the wireing. I may be wrong.
Have alook to see if they do mate up and use the .PDF file to cheak to see if the wire positioning match. You can also pull the lugs that are attatched to the wire to change the order that the wires sit in the connector.
  • 4 months later...
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
