i have a 32 gtr,
now on wendsday i took it to eastern creek and posted a top time of 11.7 at 115mph, with only a exhaust and 13psi boost, stock turbos, stock ecu
i was wrapt....
before this i could always noitce somthing like a choking feeling while the engine was reving out, and you could notice the torque loss, not massivly, but abit......
this was more only during the day time, during night it would run mad.... i put that down to intake temps
now, since i ran that time, the next day i went and put some cam gears on and set them to 2 deg advance on intake and 5 deg retard exhaust, ran the car, perfect, absolute animal compared to the 11.7 pass.... i couldn't believe it, this test was also at night, drove home, woke up im morning, and took for another drive, same as before, feeling lazy and choked up during the day, night came, abit better....
now tonight, i have noticed a big amount of power loss, and a shit load more laziness, the exhaust note has changed, sounds choked up, the engine builds boost good as i watch the gauge but its like the motor doesn't like the positive pressure its being given.... and lost throttle response...
i always put good fuel in aswell
also under load like at 2500rpm in 5th, ill put the throttle flat, and it will build boost probably up until 3000rpm and then the bov's start making their noises with my foot still to the floor...
now i think that this may be something to do with the computer, but im still unsure but wtf is the story with the bov's going off while still under load????
any1 with similar issues?? or theory's
any and all help is appreciated
cheers
denis
https://www.sau.com.au/forums/topic/226038-32-gtr-running-like-a-wheel-barrow/
Maybe you stock has picked up knock and is running the other map. Try disconnecting you battery for a while and put on the interior light for 2 minutes then reconnect everything. Possible??? Also try the diagnostic on the ecu?
The factory ecu can by what I've been told reterd timing if it sensors knock something a pfc cannot.
Make sure your cat converter hasn't melted to pieces and become an exhaust restriction.
Only takes a minute or two to pull it out and have a look, and wont be difficult to replace if it is your problem.
ok, the cat is gutted aniways,
now i resset the timing back to standard and it seems to have more torque again, but that choking issue is still there, after about a 20 min drive when everyting warms up good, the choking issue rises again, could it be the o2 sensors???
i know that the cat o2 sensor is not there and the wire has been cut..... and they are definatly not touching....
yes 11.7 with only thoes mods...
pitty it wouldnt do a 18.7 now, jokes
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
