TokyoTaxi Posted June 29, 2008 Share Posted June 29, 2008 As per the title. Would really like info on diff ratio's for the following please or links to the info. R34 GT - Manual - Auto R34 GTV - Manual - Auto R34 GTT - Manual - Auto Thanks. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/ Share on other sites More sharing options...
666DAN Posted June 30, 2008 Share Posted June 30, 2008 R34 GT - Manual - ????? - Auto - RC43 - 4.36 : 1 R34 GTT - Manual - RC41 - 4.11 : 1 - Auto - RC40 - 4.0 : 1 Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-3980408 Share on other sites More sharing options...
TokyoTaxi Posted June 30, 2008 Author Share Posted June 30, 2008 Thanks Dan. You would'nt happen to know if an R34 diff ( non GT-R ) is the same as R33 GTS-t in fitment ? What I want to do is put a lower ratio diff in my car to get more out of the revs ( especially on the Freeway ). The GTT - Auto - RC40 - 4.0 : 1 diff might be just what I need. Really need to find out my diff ratio now Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-3982164 Share on other sites More sharing options...
666DAN Posted July 1, 2008 Share Posted July 1, 2008 No, from memory the backplate is different, you may need to swap it over. The R34 and S15 can interchange, not the R33 though What does the plate on your firewall say? RC40, RC41 or RC43? Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-3984611 Share on other sites More sharing options...
TokyoTaxi Posted July 1, 2008 Author Share Posted July 1, 2008 Slaps own forehead........ Just looked and it's RC43. RC40 looks like it'll be a winner. Thanks for your help Dan Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-3985858 Share on other sites More sharing options...
dori34 Posted September 19, 2008 Share Posted September 19, 2008 (edited) what centre can i use to put it in a r34 25GT ? atm mines only a single spinner so i want a lsd that spins both wheels. would a r33 gtst diff centre fit? what about a S14 or S15 one? can i just shim up the standard centre i have now ? Edited September 19, 2008 by dori32 Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4142842 Share on other sites More sharing options...
Abo Bob Posted September 25, 2008 Share Posted September 25, 2008 Some info: GTT auto diff is 4.089:1, manual is 4.111:1. The difference is unnoticeable. I put the diff centre from an R33 into my GTT and it bolted in perfect. We looked at doing the housing but it didn't look like it would fit, although I think the one we had was a non ABS R33 so perhaps that was the reason. I bolted an R32 GTR diff, housing and all into my GTT. The traction control stopped working but I didn't care. The ABS still works. Scott, if you're still looking, I can ask Dan if he still has my old 4.089 centre lying around. I left it at his place as that's where we did one of the swaps. It single spins when hot but with no turbo this may not matter and would be free. Otherwise, anyone who has put a mechanical centre in an R33 or R34 GTT will have their old worthless centre lying around which you could use. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4155703 Share on other sites More sharing options...
TokyoTaxi Posted September 25, 2008 Author Share Posted September 25, 2008 Some info:GTT auto diff is 4.089:1, manual is 4.111:1. The difference is unnoticeable. I put the diff centre from an R33 into my GTT and it bolted in perfect. We looked at doing the housing but it didn't look like it would fit, although I think the one we had was a non ABS R33 so perhaps that was the reason. I bolted an R32 GTR diff, housing and all into my GTT. The traction control stopped working but I didn't care. The ABS still works. Scott, if you're still looking, I can ask Dan if he still has my old 4.089 centre lying around. I left it at his place as that's where we did one of the swaps. It single spins when hot but with no turbo this may not matter and would be free. Otherwise, anyone who has put a mechanical centre in an R33 or R34 GTT will have their old worthless centre lying around which you could use. Cheers for the heads up. It's sort of a project on the slow boil atm. First thing I'm pondering is what sort of speedo error will result if I change from a 4.3 ratio to a 4.0 ? Who's good with maths ?? Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4157302 Share on other sites More sharing options...
Abo Bob Posted September 25, 2008 Share Posted September 25, 2008 For every 1000rpm at 1:1 gearbox ratio, so 3rd gear in an auto or 4th in a manual, with a 4.083 diff (I found the figure, last time was off the top of my head), you do 29.7km/h by my calculations. This is 3370 rpm at 100km/h. With a 4.3 diff it's 28.1 so 3560 rpm at 100km/h. So a drop of nearly 200rpm with the different ratio. I think this is 5.3% out on the speedo so if it shows 105 then it's actually 100 and since it's likely without the diff change to be doing 102-103 when showing 105 already, there's only about 2km/h for you to worry about when Mr Plod looms over the horizon. *It's early in the morning so I may have stuffed something up but it sounds right. 1 Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4157330 Share on other sites More sharing options...
bra0063 Posted July 12, 2011 Share Posted July 12, 2011 hi guys im also interested in changing my NA r34 gt coupe's diff ratio i looked at the firewall plate and it said ive got a RC40. i looked up and someone said they should have an RC43? does anyone know where i can get a diff with different ratios to it will be more responsive? and also any info about shift kits for auto's as well in victoria. cheers. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-5909488 Share on other sites More sharing options...
bra0063 Posted July 12, 2011 Share Posted July 12, 2011 hi guys im also interested in changing my NA r34 gt coupe's diff ratio i looked at the firewall plate and it said ive got a RC40. i looked up and someone said they should have an RC43? does anyone know where i can get a diff with different ratios to it will be more responsive? and also any info about shift kits for auto's as well in victoria. cheers. why are the stock diff ratios so high also? is it even possible to make them higher? Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-5909569 Share on other sites More sharing options...
Abo Bob Posted July 12, 2011 Share Posted July 12, 2011 You already have the highest one available. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-5909691 Share on other sites More sharing options...
R32FREAKK Posted April 1, 2014 Share Posted April 1, 2014 hey guys reviving this thread, so do all r34 25gt 4 door autos come with a final drive ratio of 4.363 in the diff? Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7245908 Share on other sites More sharing options...
GTSBoy Posted April 1, 2014 Share Posted April 1, 2014 hey guys reviving this thread, so do all r34 25gt 4 door autos come with a final drive ratio of 4.363 in the diff? Hard to say. See bottom of page 3 for confusion. http://www.nismo.co.jp/en/products/competition/lsd/pdf/lsd_price.pdf You can see 2WD R34 NA autos have both the 4.083 and 4.363 diffs. But if you look really closely you'll see that NA cars with a viscous LSD have the 4.083 ratio and the cars with open diffs came with either. This table is supposed to be accurate, but in reality, the number of R34 (GTT) helical LSD cars that actually appear to have been made is close to zero, despite being in the table. They exist, that's why they're in the table. On the same basis, there might be very few or almost none of the RB25DE autos with the 4.083 ratio. Or there could be lots. I don't know. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7245933 Share on other sites More sharing options...
Adz #24 Posted July 26, 2018 Share Posted July 26, 2018 Reviving this thread. My GTT was originally auto and was also converted to manual in Japan, it states that I have the RC40 but how I can check to see whether this is still the case. Also if it hasn’t been change previously and still is the RC40 what would be the best option keep it as is or change it for something else. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7881932 Share on other sites More sharing options...
GTSBoy Posted July 26, 2018 Share Posted July 26, 2018 The ratio is stamped on the edge of the crownwheel (# of CW teeth and # of pinion teeth). Take the cover off and see for yourself. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7881934 Share on other sites More sharing options...
KiwiRS4T Posted July 26, 2018 Share Posted July 26, 2018 3 hours ago, Adz #24 said: Reviving this thread. My GTT was originally auto and was also converted to manual in Japan, it states that I have the RC40 but how I can check to see whether this is still the case. Also if it hasn’t been change previously and still is the RC40 what would be the best option keep it as is or change it for something else. If you don't have a reason to change the ratio then leave it alone until you think of one. If you are going to double the power you may want to get an LSD but not necessarily change the ratio. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7881943 Share on other sites More sharing options...
Adz #24 Posted July 27, 2018 Share Posted July 27, 2018 Thanks GTSBoy I’ll have a look into that and see what I have. What would be a good option if I wanted to go to an LSD and change it to a Manual ratio 4.11 : 1? Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7882027 Share on other sites More sharing options...
GTSBoy Posted July 27, 2018 Share Posted July 27, 2018 Why change from 4.083 to 4.11? Makes no sense. You will never tell the difference. As to the LSD.....The Nismos are broadly considered to be the nicest. 1.5 way for the street. 2 way for hardcore carpark action. After that, Cusco, etc etc, are all rather similar. Some have different features (like being able to alter the config from 1 to 1.5 to 2 way). Some are really harsh to live with but can be moderated a little with different oils. Have a read on here for mentions. If I was to replace my helical, I would probably go Nismo. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7882034 Share on other sites More sharing options...
Adz #24 Posted August 18, 2018 Share Posted August 18, 2018 On 7/27/2018 at 8:14 PM, GTSBoy said: Why change from 4.083 to 4.11? Makes no sense. You will never tell the difference. As to the LSD.....The Nismos are broadly considered to be the nicest. 1.5 way for the street. 2 way for hardcore carpark action. After that, Cusco, etc etc, are all rather similar. Some have different features (like being able to alter the config from 1 to 1.5 to 2 way). Some are really harsh to live with but can be moderated a little with different oils. Have a read on here for mentions. If I was to replace my helical, I would probably go Nismo. Thanks for the info. The issue I’m having with my r34 gtt sedan that has no major engine mods that was converted to manual in Japan is that I’m losing traction way to easily in 1st and sometimes in 2nd, (powers just not making it to the ground properly). I’m moving to a wider wheel setup so hopefully this reduces the loss of traction a bit but if not I’m thinking the next option is changing/upgrading the diff. It’s my daily driver so 1.5 way would be where I’d want to go. Would a vspec GTR diff be an option? As you can probably tell I’m new to this so slowly learning my way around things. Link to comment https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7883444 Share on other sites More sharing options...
