  • Replies 325
I'm not sure why you guys are so anal about editting number plates....not like anyone has court cases pending about an alledged crime and as far as finding peeps by their plates, I can't even do that unless I have a section 110 from workcover or a magistrate.......or know a crooked cop whose days would be numbered in the force.
Is it forum rules maybe or something that I don't know about?
i tend to just do it out of courtesy, some people arent a fan of their plates being posted.
ill probably just get bored and post them all unedited anyways though.
I hate most pics of me... but they don't look too bad thanks Daniel!! r they all the shots of the stag? I should have joined here a year ago i could have gotten you to take my wedding pics hehe.
Luke.. i love your wheels!!!! What offset are they, Ben wants to know if that style of rim would fit the stag??
Lookin hot as usual Nene!
Wish I could have joined in at a later time. But I had a full day ahead of me.
Tracy wasn't in the best mood ... and me picking a fight with some rude abos didn't help :thumbsup:
Hey Kell, thanks for a good day out! Was great to catch up with everyone and put faces to a few names! Me and Nene had a really good day, was good to put a fewkms on the 260 aswell, hope i didnt give anyone hearing problems! lol! Let us know when you plan the next one kell and we'll do our best to be there, hopefully by then the stag will be fully tuned and running better!
Only one suggestion for the next one, lets not meet up with the police cruise that was apparently on that we bumped into at the end! :D
"........ah yes officer, thats my family wagon...." yeah, you keep thinking that...lol
AWW thanks Roo...
Stop picking fricken fights then!! 2 words... ANGER MANAGEMENT!! lol
Ha. I think it was the abos picking the fight with me ... problem was I wasn't backing down :O Nothing to do with anger management babe. As a matter of fact, I ignored them for the best part, and didn't thump them. :D
Tracy, Cam and I grabbed some lunch before watching a movie. Sat down waiting for Tracy with the food. When Tracy arrived we were 2 less seats. I asked the group next to us (abos) if they took the seat. Their reply was "you weren't f**king using it, its ours now". I told them I was reserving it for my GF and son and they could have asked. They started the racist remarks and raved on about how they'll f**k me up and shit like that. I politely asked them to STFU while Cam was present. After 5 minutes of slagging me off I finally said to them "You're to stupid to know I've been ignoring you for the last 5 minutes. Why don't you f**k off!". To which they did after a while. Still cursing me, but they did f**k off. :P
Tracy asked me later what I would have done if they started getting physical. My response was that I'd tell her to take Cam and get security and not to look back at what would happen. :P I do not have an anger problem :D :D
The whole time me and kel were talking to them they just kept bagging commodore drivers... lol
They got that stereotyping correct then :D
Good to see the 'family wagon' didn't get inspected closely :D
So Nene, when are we doing photo shoots with the Brutale again? :O
I'm feeling lucky this time :D
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
