1) SR20DET Red top Engine, It has inlet manifold, alternator, power steering pump, complete head, block, crank rods and pistions, sump. There is no turbo, exhuast manifold, throtle postions sensor, loom, computer, distributor or coil packs. This engine had number 2 conrod cap come loose and jam the engine. There is no damage to the crank, block or head but the cams are worn.
Perfect for a rebuild
$300 ono
2) SR20DET Starter motors x2 $100
3) S13 front 4 stud hubs $60 each or $100 pair
4) Passenger S13 side guard $50 there is a small dent
5) Brand new flexable clutch master cylinder to slave cylinder pressure line $50
6) S13 LCA with new ball joint boots $60 each or $100 pair
7) Standard S13 front castor rods $ free
8)Damaged (broken mounts) S13 front head light projector/round light style $ free
9) Standard RB25DET exhaust manifold with studs $ free
10) 180sx front LHS head light cover painted mat black and straight $50
11) S13 airconditioner condenser and dryer straight with not many bent fins $ free
12) S13 standard front sway bar with good bushes x2 $ free
13) S13 CA/SR engine cross member $50
14) S13 rear 4 stud hubs $40 each or $70 for the pair
15) O2 sensors 3 pin x2 $50 ea
16) Standard S15 side mount intercooler with all piping $ 50
17) S13 HID instrument cluster with HID attachment speedo is at 105,649km no Tacho works perfectly $ 50
18) R32 GTR matched set crank, rods and pistons $ 100
19) S13 front brakes with near new pads and good 250mm rotors $50 each or $90 for the pair
20) S15 SR20DET block bare fair condition $350
21) S15 SR20DET crank fair condition $150
22) S13 6 bolt half shafts $50 each or $90 for the pair
23) S13 rear sway bar with links $free
24) S15 SR20DET oil pump good condition $50
25) S15 SR20DET TPS excelent condition $50
26) S15 SR20DET harmonic standard balancer $50
27) S13 rear brakes with near new pads and rotors $40 each or $70 for the pair
28) SR20DET viscous engine fan $20
29) S13 brake booster fair condition $50
30) S13 6 speed conversion kit S15 6 speed with 40xxx kms on box, Geniuine 'C's short shifter, Moded tail shaft for the conversion
OS giken twin plate clutch with OS flywheel, Gear box crossmember to suit conversion in a S13.
$1750 ono
31) SR20DE distributors in excelent working order x2 $ 25 ea
32) S13 SR20DE engine loom complete un cut/murdered $25
33) S14a SR20DE engine loom complete un cut/murdered $25
34) 18" x 8.5, 4 stud multi fit rims with near new tyres 235-45-18, and a set of 30mm bolt on spacers with wheel nuts $1,000 ono
35) S15 SR20DET VCT motor in parts all that is needed is coils, injectors, injector rail, exhaust manifold, cams, cam cover, bearings and gasket kit. comes with ACL 20 thou over sized pistions with hasting pistion rings on standard rods with ARP con rod studs, head has bigger valave springs and with port and polish job, freshly honed block and excelent crank, fresh oil pump and chain, fresh chain tensioner, standard harmonic balancer and engine mounts etc.
No turbo, distributor, coil packs, loom, computer, flywheel.
$ 800
ALL PRICES ARE NEGOTABLE
I have pictures of all parts but my camera is to detailed and the pictures are upwards of 1.5MB so pm me your email and wahat your interested in and I'll send them to you. Sorry about the inconveniance
All prices are negotable pm me on here or call me on 0406 046 136
I'm located in Ipswich QLD.
Cheers
Luke
https://www.sau.com.au/forums/topic/226111-s13-s14-s15-and-some-skyline-parts/
ร—
ร—
