  • 3 weeks later...
  • Replies 48
Any luck on this Cubes?
Do you have a link to Tighe cams also? Am trying to sort some out at the moment. 272 degree with 9.5 lift can apparently be done on a regrind, whilst Kelfords who build some impressive cams suggest welding to a camshaft isnt at all good.
yeah they turned out good.
We haven't played with the cam gears as it wasn't able to hold more than 17psi up top.
The same thing occurred before the cams so I'm putting it down to either the FMIC with its 2" piping and or a weak actuator that is quite lazy. Most likely the later.
Mine haven't been built up as they were GTR sticks. The Rb25 sticks apparently do have to be built up.
It went on to make.
3k - forget? :O
3.5k - 200rwkw
4k - 256rwkw
5k - 288rwkw
6k - 302rwkw
7k - 290rwkw
Its awesome to drive. Third gear at 60km/h slightly flick the brake and its up making 19psi and then storms off quite a strange feeling with the motor not reving but your being sunk in to the seat hard.
I was a little off with my overlap calcs. Its actually running around 39degree's overlap so not all that good for top end 'apparently'.
I'll get it on the dyno once I fit an 18psi actuator and new fmic with 2.5" piping and play with the cam gears to shift peak power ~500rpm higher and then stretch its legs slightly to ~7300rpm.
Fuel economy has slightly improved; we spent a little more time on the accelerator injection time and tweaked the afr's.
Sounds really good mate.
GTR cams people here still want 300+ for so i think a set of billets from Greenline etc may eventually work out cheaper by the time they get the regrind treatment.
My thing should be going in the next 3 or so weeks so will consider a new cam come full tune time.
Couldnt find an rbcam on tighe cams website.
Have you heard anything re weld on tips being dodgy at all?
Will look forward to seeing the results. Lith mentioned to me a while back you were having a few issues since the cam install. Dont think that 2" piping could help, not the actuator.
Edited by SirRacer
Bugger.. I have seen a few sets go for 60-100. I picked mine up for 60.
Ebay is another place to look.
Tighe haven't updated their website for a bit by the looks so chances are it won't be there.
Not sure exactly what the problem is.. FMIC is first so I'll know soon enough :(
If not done right building up the cam can be dodgy. Not sure.. If you can't grab a reasonably priced set of gtr cams then by all means grab a set of cams from nengun. :)
$300 for a pair of stock cams is dreaming. What are they useful for lol.
Hi Guys,
just a quick question.
i have a R32 rb25de head with no cams and was thinking of getting the following:
2202-RN170, IN (256deg) (Lift 8.8) (valve timing 110)
2202-RN175, EX (264deg) (Lift 9.0) (valve timing 115)
what are your ideas on how these will go on a RB30/25 build
  • 2 months later...
hey guys
instead of starting another cam choice thread what are you opinions of different sized inlet and exhaust cams.
looking at the HKS step 2 cams. will only be reving to 7k but will have an 8k limiter for power runs and drags.
however car will be more of a daily, just want that phat idol...
was first going to go with the 272 10.2 inlet and a 280 10.20 but am thinking the 280 will be bring power on too late. or should i stick with both at 272 10.2??
turbo will be a gt35r at 1.5bar undecided rear housing.
obviusly springs will be upgraded to suit but will the head need modifing to drop these bad boys in.
I believe there is an 806C grind. Not sure on its specifics but thats where it ends.
More than a 265 duration and 9mm lift and you need valve springs, you'll need to machine the buckets.
Rip the head off spend $300 on a set of valve springs, machine the buckets and drop in a set of 10.5mm lift cams. :(
I probably wouldn't bother regrinding a set of pon cams as you can still fetch good $$ for them s/h and then put a few hundred towards a new set imported from nengun or the likes.
A set of cams from Nengun are worth 800 odd delivered depending on brand.
Where can i get a set of valve springs for $300?
Oh and by the way, I'm using some Gibson Motorsport cams( same as the Winfield GTR). Just had them cam doctored.
At advertised duration
Inlet 256 @ 9.5mm lift
Exhaust 278 @ 9.75 mm lift
...don't tell to many people :(
Edited by BoostdR
...don't tell to many people :P
Interesting aswel they have such a large difference between duration for in and ex
Are you in Sydney? I would very much appreciate the chance to see how it goes with your turbo setup. Its the same as mine expect for cams, ive got 270 10.25 in and out :D
hey guys
any opinions out there. is 280 to big for my rev limit
Interesting you guys dont go for cosworth springs, good for 12mm lift and 400USD a set so compared to 12mm capable springs from japan they're about a third of the price
the guy i get to do my cylinderhead work doesnt like the jun (cosworth) springs as they dont have much tension. his pick are some dual psi springs, second to them the supertech springs
  • 3 weeks later...
  • 3 months later...
Awesome.. Allways been curious what cam specs they ran.
QLD Performance Springs :cool:http://www.performancesprings.com.au/
how do these springs compare to the likes of japanese brands, i.e. tomei?
...Mr 'N1GTR' - can u send the link of these cosworth springs u mentioned in this thread?
Edited by Marko R1
the psi springs (i think they are the same as the performancesprings) are rated as the bees knees in the top end springs (dual coil) by my head guy, jhh performance. its the quality of the wire used makes them good as they can happily sustain all the requirements of a high revving high load valvetrain. the daul springs arent cheap though and not really needed unless ur going to competatively race it, id look at some supertech or ferrea springs or the cheaper single coil psi spring
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
