::Car::
1988 nissan silvia
series 2 RB25det
c33 laurel xmember and engine mounts and r32 engine brackets
i did the conversion over the last christmas period. when i did it the motor received a genuine timing belt, water pump, rear main seal, cam cover gaskets, exhaust manifold gaskets, new heater hose and radiator hoses and belts.
exedy 5puk brass button clutch
modified standard loom so it is plug in and play so can be run on a standard ecu if need be
microtech lt12s and microtech dash
hypergear tr43 440hp turbo
full custom 3" exhaust straight through to a 4" pipe. Or instead of 4" pipe a normal cannon. because the front pipe and dump pipe were custom done by muffler kings the exhaust is very tight to the body so it is not the lowest part of the car. the rb25 is not as loud as the CA was with the pipe but the cannon would be very advisable to drive everyday.
440cc injectors (not installed yet)
adjustable exhaust cam gear
greddy type r bov
front mount intercooler
40mm alloy radiator
2 x 12" thermos
19 or 25 row oil cooler
blitz dsbc iD3 boost controller
::Suspension::
ISC coilovers 10 & 8kg springs
ikeya formula tie rods
adjustable toe rods
adjustable rear camber arms
adjustable castor rods
KTS tie rod ends
rear strut braces
rear adjustable whiteline swaybar
cefiro front swaybar
front and rear lower control arm bushes have been replaced with superpro and nolathane bushes
alloy subframe bushes
Cusco mech lsd
::other bits::
recaro drivers seat (reclinable) OR black fixed back seat (same as bride zeta 2) and TRS harness
r33 passenger seat
autometre oil temp gauge and oil pressure
greddy boost gauge
the mintest nardi i have ever seen (bar a new one)
detachable boss seering wheel
r32 skyline front brakes
slotted rear brakes
full vertex kit with wide front guards
standard perfect blue bonnet and hektik FG bonnet painted satin black
also has bn front and rear bar
work CR Kais 17*8 +25 with advan neova AD07's (these are steer tyres with 30mm spacers making them effectively 17*8 -5)
4 x Grenades (look like r34 gtr wheels) in chrome 17*9 +15 (skid wheels)
rays wheel nuts
rolled and flared rear guards
sticker tuned
boot mounted battery
selling now because the car market is very slow and im going overseas in 6 months so thought i better put it out there now
chasing 16500ono depending on whats included. currently the front guards, front and rear bars have scratches on them. this will be fixed before sale or sold cheaper with them not fixed. currently its not mod plated but will be done before sale and can come with a rwc. the only things stopping it from a roady is height, mod plates and lack of cat. this car is genuinly quick and bakes tyres with ease. its nothing like driving an rb20 where you have to be bashing the clutch to get any response, this is a matter of throttle control.
ive probably missed a couple of things so if you have any questions fire away
contact me here or pm me
email: [email protected]
located in toowoomba qld, if someone interstate is interested i would freight at their cost
https://www.sau.com.au/forums/topic/226177-s13-silvia-rb25det/
sweet looking car man. how much power it putting out. love the mags on it
thanks. its only about 200kw at the moment. will have the s15 injectors in sooner than i expected so will have a bit more then
car now has standard metal guards rather than the fibreglass ones. the metal guards looks nicer and with the wheel fitment looks great
  • 4 weeks later...
car now has a bride brix 2 in much better condition than the recaro and has a vanquish roof spoiler and is being tuned on thursday with the s15 injectors in.
will post the dyno sheet then too once its tuned
car has the s15 injectors in and tuned to suit. front and rear bar and new guards are being painted within the next month or sooner if someone wants it before there done. or i will sell it lots cheaper without it done.
if your interested make an offer.
it will be going on carsales soon
  • 3 weeks later...
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
