Here is a quick rundown of my recent dyno run with my R33 GTR and a problem I found:
at 14.3 pounds, the car showed a Air Fuel Ratio of 15.6 (lean)
the Air Fuel Ratio went from 15.0 at 116KPH all the way to 15.6 at 130KPH
Temp was 37.2
The car has no boost controller and was running stock boost (1 bar)
Max power output for the run was 173.8KW
Is this a 'average' power output for a near stock 95' R33 GTR non v spec with cat back exhaust, pod filters and Nismo chipped ECU?
I know car is running dangerously lean so, is there anything I can do temporarly until I get a Power FC unit??
I dont want to buy a APEXI AFC as I see it as a waste of money as I'll be getting the PFC which does everything that this device does and more.
Any advice you guys can give would be great.....Thanks.
I'm with the others here. Try putting standard comp back in it to start with and see what that does. Second (and my money is on this) that the oil from your Pod filters has burnt onto the air flow meters and screws up the signal from them. (This was happening too my car when I got it). Take them off and get some carb cleaners and contqact cleaner and clean them up. This should fix them. Then if this does not work, start checking fuel pump pressure. I would put large sums of money on it being one of these things. Where are you located??
Mick.
You would almost be better to create a boost leak in order to get the mixture rich (a small boost leak would really help at WOT)
But it's really a BandAid solution....I wouldn't push the car until you fix this....
At this A/F don't push it otherwise you will ear BBBBBOOOOOOMMM
If you have some electrical knowledge you can do it simply/cheaply/temporarily by amplifying your AFM signal across the board. ECU thinks there is higher load and adds more fuel. This AutoSpeed article how to do it with two potentiometers, but you may need to be a member to see the whole article.
It doesn't address the root cause of the problem, and if it was my GTR I would park it until the PFC arrived.
I ordered a Apexi PFC with hand controller and boost controller today so hopefully when I get it, it will fix up the problem.
I would love to leave it parked but it is my everyday car so, as long as I dont strap it - I should be fine *fingers crossed*
I've also booked it in with my local mech who will check the fuel pressures and perhaps give my injectors a good clean also.
Any ideas on the right spark plugs to use and also the correct gaps for a stock GTR?
I was also going to upgrade the fuel pump to a Bosch 910, is this much better then the GTR pump? 190 vs 210 for the bosch if I remember...
I would love to put a stock GTR ecu in but, being in Darwin - not many GTR's are up here to borrow one from.
Gav.
Check your air flow meters, check your air flow meters. If theseare dirty no matter what you do you will have problems. It is a 1/2 hour job to clean them and will cost next to nothing. At least get this done as well as check your fuel pressure. If these are not right then tuning the car will notwork.
Mick.
JUN R33,
firstly, i'd get my fuel system checked out while running it up (i.e., fuel pressure, fuel volume flow, injector duty cycle, etc)
although, it could also be due to your intake charge being mixed with oily mist from the small amount of piston blow-by being produced by the engine and recirculated back into your intake.
you can confirm this by checking to see whether your intake pipes (before the turbo) are oily.
if this is the case, the air/fuel mixture being forced into each cylinder is not able to burn properly causing lean mixtures, therefore, i would recommend you get an oil/air separator fitted.
good luck and let us know how you go.
If it leans out at high revs. an other fuelpressure regulator won't help.
then it's most proberbly your fuel pump thats the problem.
the problem is that it can't produce the fuel flow that the engine needs. Easy too check. Just fit a pressure gauge temporarly on the fuelrail before the reulator and see if the pressure drops at high revs. But what ever you do!! DON'T get any leakage and don't have the gauge inside the car!! Clamp it under one of the wipers. I promise you that you don't want fuel in your eyes. You go blind quite a while!
Wiktor
Why couldnt that dyno place tell you why your car is running lean? If they are worth any money at all,then they should be able to find out what is causing the problem otherwise i would take it elsewhere.Up my way,the dyno operators can determine the problem and fix it usually in a day or two without band-aid solutions.
Thanks to everyone who offered their solutions and ideas to my AFR problems.
well, here is an update:
My O2 sensors are not faulty and are in working order.
The car came with a set of uni filters which might have had oil burnt onto the air
flow meters and screwed up the signal but, I cleaned my AFM's anyway and even though I
didnt notice a difference,it was a good thing to do to the car.
I have a set of M's K & N pods on their way to replace my uni filter pods.
The car is booked in this week to have a fuel pressure check and BOSCH 910 fuel pump
fitted.
My guess to the AFR problem is that the fuel pump could be faulty.
Hopefully the changing of the fuel pump fixes the problem or I start pointing the finger
at the injectors or Nismo ECU.
I Was going to get a stock GTR ECU to see if it made any difference but since the PFC
is only a few days away, I will wait for that to arrive.
Anyone have any idea what type of spark plugs are best used on a GTR and the proper gap
measurement?
I can only wish that I had more then one 4WD dyno place to choose from but, there isnt and
I have to put up with the only one we have here including our 'best' available 95 RON PULP
fuel.
Anyway I will keep you all updated and post up some pics of the dyno run and a few
pics of my GTR in the next couple of days.
Gav.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
