ok ive upgraded my turbos, and now have my old ones in the store room.. i found that they both have a letter 'S' hand written on them..
when i bought my car, it seemed completely standard, and to write on the turbos, the turbos would have have to be taken out sometime.. so now im thinking whether i have standard turbos or not.. how do i identify what turbos i have? i know they are Garrett..
markings on it say - "GARRETT A/R42 M24 1-2" and .42 on one of the tubes and 4685 on the side and
"GARRETT 485" .48 on the other (darker one) i hope u get what im saying here =/
a plate on it says
"UD 1429J
14411-05U20
466071-2"
can anyone let me know what turbos i have? and how would i know if they are 'steel wheeled' turbos? thanks in advance
https://www.sau.com.au/forums/topic/226205-turbo-identifcation-r32-gtr/
They are standard size housings, I can tell you that much. the 42 or .42 is the A/R of the front housing and the 0.48 is the rear. the "14411-05U20" is a nissan part number, so they are a nissan turbo, and given the housings sizes are standard I would say they are stock. It's possible they have been rebuilt, and perhaps given steel wheels, but also possible they were just removed for some other reason and re-fitted at some point.
cool, thanks for the info, but is there some way to tell if they are steel wheeled? i cant think of a reason why they would take it off (unless they blew) and write an 'S' on both turbos.. unless its steel wheeled, maybe its just wishful thinking, but is there a way to be sure?? thanks
Take a photo looking in at the front and rear of the turbo, close enough to see easily the shaft at each end clearly. post it up here and it won't take much.
i can get the front shaft but the back has the dumps attatched at they are really tightly bolted on, ill get u the front shaft pics for now, back in 5~
if theres one thing ive learnt with imports is
dont trust the work unless u do it urself..
my car was suppose to be stock when i bought it.. made 296awkw... i thought instantly.. cant be stock turbos
and sure enough they werent stock.. they had a fairly large compwheel..
but ceramic exhaust wheel... so @ 18psi 1 snapped off and destroyed the motor
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
