Any one that deals with NGK plugs can order them in. I seriously doubt you would need to go 9 or 10 heat range plugs. Maybe 8.
My old mans blown ls1 Monaro has around 620-650HP and he uses BKR6E plugs with no dramas at all. If you start going towards 9 or 10 heat ranges you will barely be able to start your car on cold start in the mornings. Like i said, try the 7 heat range and if its a problem go towards a 8. At the end of the day its going to cost you around $18 for a set of copper plugs so if you get the heat range wrong its not the end of the world.
Hopefully your coil packs are up to scratch, if not get a set of splitfires and put in a HKS twin ignition system and i seriously doubt you will have any dramas.
hehehe, 881@ all four and using 5 dollar ngk's. its all in the timing dude, get it right and they only need changing every
10 000 kms. if its retarded or using shit fuel no sparkplugwill last that long you should change em when you do ya oil anyway.
