Hey guy's I've been looking everywere for a carbon bonnet to suit a R33 series 2
just don't want one with fifty odd grills in it just a nice neat bonnet with one or two vents tops if anyone know were I could find one that would be awsome thanks
https://www.sau.com.au/forums/topic/226261-carbon-bonnet-series-2-r33/
<-----ive got this one, the previous owner said he got it from unique auto sports, its got the big centre vent and the 2 smaller vents either side, one ontop of the turbo (which after abit of a hard drive, vents ALOT of hot air out) and another on the other side
suits me fine coz it came with the car hehehe
Sounds like the same CF bonnet i'm looking for, something more on the plain side.
+1 id also be interested in a simple bonnet, with maybe 1 or 2 subtle vents. maybe if anyone knows a custom place we could get a group buy going
I wish we could design a carbon bonnet that suits everyone :D
We can always get a carbon bonnet made that suits your style however there must be a minimum order of around 10.
Sounds like a group buy what do you think boys? I'm keen let's get the numbers!! :rofl:
Sounds like a group buy what do you think boys? I'm keen let's get the numbers!! :D
im in pending the design.
all i really want is something that will allow through ventilation. so some sort of reverse facing vents mid way up the bonnet. im not to fussed about the final design as long as its not flashy or attention drawing.
Edited by 33drifter
We have just received stock of these S2 bonnets. We trial fitted it onto our demo car and it fits very well and makes the front look very aggressive, no to mention providing extra cooling, especially over the top of your ignition system where it is needed most.
I think in all the excitement we forgot to take a picture before we took it off :(
Carbon $749, FRP $499
Comes with all the required mounting hardware too. Bolt threads are fibreglassed in and line up perfectly with the factory bonnet hinge.
Now obviously these aren't ADR approved? (not that i really care)
Would you have to use bonnet pins with it or is the part where the lock mechanism goes pretty tuff?
Also with the carbon fibre one, is it carbon fibre on the inside of it aswell?
Sorry for all the questions but this is probably one of only a handful of bonnets that i have seen that i actually like for the series II.
No these are not ADR approved, I have been trying to speak to someone about what is required for ADR approval but am yet to find anyone that can give me a clear answer or the right person to speak to. Can anyone help me here?
The bonnet catch area is strengthened however, pins are always a good idea. If you do want pins, my preference would be to get AeroCatch.
These do have a FRP skeleton with a Carbon top layer. We can certainly make you one that is made totally from carbon fibre, although expect to pay a LOT more.
I'm more than happy to answer your questions.
PSI do you have any bonnets for series 1 GTR 33
Not at this stage, there just hasn't been enough interest thus far.
Can you please though it back on the demo car for a picture please and about how high do those vents stick up?
And the bonnet pins you refered to are they flush mounted, do they have extra locks the ones I've seen are flush and have locks in each bonnet
pin oh how much for the bonnet pins too?
Just noticed your in melbourne any chance I could pop round and check it out for myself?
Edited by The BOP
Yes the bonnet pins I were talking about are flush fitting and have an optional lock, unfortunately we don't sell them though
Here's a pic:
I'll see what I can do about a picture on our demo car for you. Please PM me about pick-up.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
