  • Replies 57
Posted Images
Thanks guys for all you kind words and congratulations. It means a lot to Min and I.
Min got a very special birthday present this year!!
Ryder Arran Thomson
Born 2nd July 2008 @ 10.03am
Weight - 2.55kg (5lb 10oz)
Length - 44cm
He was 4 weeks early and took us completely by surprise! Min took the Tuesday off work as she was getting slight pains, but didn't think it was happening at all - She just felt uncomfortable. But then Wednesday morning at 5am the waters broke and we were at the hospital by 6 and he was born at 10.
Luckily he was just over the weight break (2.5kg) where they get taken to the special care nursery. That meant that he got to stay with us in the room until we were allowed to go home. We ended up having to stay for 5 nights and we were getting a bit over being in the hospital at the end. He did have to spend 24 hours under the UV lights as he had a bit of jaundice. (Yellowing of the skin, because of too much red blood cells and only small liver to break them down)
But we are home now and settling in OK. Min still can't believe the cheeky monkey stole her birthday!! Min was supposed to finish work on the 4th and have 4 weeks off to get organised and have everything ready!
Because he was early we hadn't decided on a name so he was the 'little man' until he finally got his name on Monday night. Min picked his first name from the book and had liked this name from about a week ago, but it took me a while to be comfortable with it. Once I accepted that we weren't allowed to rename the dog, Linkin, to retread, the baby's name all fell into place . We had already decided on the middle name a long time ago, as this is the Scottish spelling of Aaron (Arran) and is the name of the island off the coast of Ardrossan, Scotland which is where I was born and where my Grandparents still live along with most of dads side of the family.
We already have too many pics, as the granparent paparazzi were snapping away constantly.
Cheers,
Chris, Min & Ryder
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
