  • Replies 120
Guest KILLER-T
Well im glad someone knows what happend to it because i dont it might of been the tune it could of been me thrashing it to much or it might of been the usless shop that did my first cooler.I couldnt point the finger at anyone i would of liked to but im still not 100% sure why it died.All i know is it cost alot to get fixed :)
Its running about 322 at the moment, as soon as we put the bosch 910 pump in it richened up the top end of the fuel map again :) So far the turbo's been on for 3 weeks, maybe 4 weeks now... havent had any issues, pulls like an ox, until the feel the stock ecu pulling the timing out and retarding and then dumping in a heap of fuel. I cant wait to get the wolf3d in, it will make such a difference, go for a ride in paul's car thats a monster, breaks traction so easily and pulls nice and hard. Steve at sst reckons 350hp @ treads is fine for the stock internals, just make sure you service it regularly... but with that sort of power you can be living on borrowed time, its not like our engines are spring chickens... mine is 8-9 years old now and coming up to 85,000km's.
Oh if you want 350hp at the wheels I'd go the same way as paul with the tubular manifold and the GT30. His exhaust housing is tiny compared to mine, but it makes good HP on 13-14psi... you dont want to run high amounts of boost on the stock internals, best if you can keep it under 1 bar or 15psi.
Well grant is gonna be doin my turbo and hes pretty convinced that 350 is very easily possible with stock manifold and lowish boost. I'll be getting my wolf in the next week or so. Lookin forward to it. My car is runnin stock boost nd ecu at the moment. F#ck its slow!!
Mate I'm still running the stock manifold, so it wont be an issue. I reckon get a GT30 with a wastegate attached to the exhaust housing like mine bolt it onto the stock manifold. It will be laggier than paul's cos of the manifold but it will cut your costs by about $1200-$1400 dollars. Mine makes max boost by 4600rpm, it isnt a lag monster, but it aint like a stock turbo either :)
Yeah, full boost at 4000ropm, but we've taken timing out to limit the power, so I'd expect it to spool sooner when we can give it a more aggressive tune.
I'm definately doing the internals ASAP, but finances need to replenish.
Killer, Thanks mate, I'm happy with the result, and excited about what it will do with internals, cams and more boost:D
People that want a good upgrade on a standard motor running
300rwhp should look at a 25/30 HKS bolton or a 25/40 to do it easy.Pauls car has a soft ignition map and lots of fuel so i think
if the motor is in good condition it will last but he wants more so a build is the only way to go.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
